Question about Konica Minolta magicolor 2400 Laser Printer
Error light I refill all color toneres and replace all he chips in my Konica/minolta 2400w but by mistake instead rotate the cartridges by using top rotate button I rotate the cartridge holder with hand and after that this error acured.Please tell me how to remove this error now
  • pq_negru Feb 10, 2009
  • sgoglassbalt Feb 17, 2009
    Have replaced all cartridges, but still getting error on yellow ("Put Yellow toner cartridge" in status window.)
  • 170 Answers
What kind of error....blinking light which lights are blinking..or is it a code 17h or something like that.....please clarify for me. thank you....whytfang. In the mean time you might take all of the cartridges out and make sure they are in correctly and none are damaged...and then clean the circuit boards and the reading board under the cartridges, then reinstall them and turn the printer back on...if not fixed try again and take care with the reading board...it is delicate...and the chips should be blown clean with pressurized air...like the canned spray used to clean keyboards or other delicate computer components. Try this in the meantime and send me the other info...good luck.
Posted on Mar 25, 2009
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
Minolta 2400W errors
GO and get 4 Konicminolta image units one for each color and replace them do not use third party. NEVER ever use a vacuum cleaner the static electricity can cause sensors to go bad !!!!!!!!!!!! might have destroyed the chips on the image units SO recommend get all new hopefully you did not destroy the control board with static electricity
Apr 27, 2010 | Minolta magicolor 2400W Laser Printer
I have replace the yellow colour and ever since the printer comes up with a error saying no toner
this is a very annoying error message
Konica Minolta Magicolor 2400/2500 series printer "X cartridge not installed" One of the most frustrating features of the Magicolor 2400/2500 series of printers is the very annoying X Cartridge not installed message
This error message can occur at any time with both original cartridges and or refilled cartridges. It is caused by either toner / paper dust covering either the chip on the toner cartridge or dust covering the chip sensor inside the printer. It can also be caused by a faulty chip reader inside the printer.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Nov 03, 2009 | Konica Minolta Magicolor 2450 Printer
Error
The only way to reset the toner error is to replace the counter chip on the toner cartridge. These should go for about $10 a piece. Otherwise, you can set the engine to continue on error, and ignore the blinking light. Better yet, I put a piece of electrical tape over it. You can still read the status on the LED's, but not have your wife complain about it. Saves you $40.
Dec 20, 2008 | Konica Minolta magicolor 2400 Laser...
Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Jun 23, 2008 | Konica Minolta magicolor 2400 Laser...
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Konica magicolor 2400W
To clear chip after refilling toner cartriage.
Go to "Tonerfillyourself.com" I bought refill toner and it includes a new chip and it's not hard to replace it. (Comes with instructions)
Apr 09, 2008 | Konica Minolta magicolor 2400 Laser...
Konica minolta 2400w toners problem
My Konica 2430DL does this every time I start the printer, I am quite sure it is supposed to do this as I it rotating the toner and calibrating itself. On one occasion I recently had the status monitor say to install cartridge... I removed it, shook it, reinstalled it with the same results. I just purchased a new Konica brand toner, replacing the old one and 'voila' sucess! It still does the little dance (rotation) every time, but it always has, but after installing the new toner the message went away. If you reinstalled the toners, this may be your problem - you need all new toners; spendy but it should solve your problem, otherwise; if you've already done this, I don't have an answer. Good Luck!
Dec 28, 2007 | Konica Minolta magicolor 2430 DL Laser...
Error code
toner chip is gone replace cartrige
Oct 08, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
205 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
