Question about Dell Axim X51v Pocket PC
PDA would not turn on...
Hi! My PDA seems to be in an off mode/ sleep mode or something. It won't turn on regardless of what I do. If I don't connect it to an AC Adapter or place in the cradle where it is connect to a power outlet - the power button doesn't work even if the battery was fully charged; however, if I somehow connect it to an power outlet - the power button would turn green but nothing would appear on the touch screen as if it had never been turn on. I try resetting it but it still wouldn't work. Can anyone help me with this problem? Have anyone encounter the similiar problem? Thanks!
  • 4 more comments
  • cgh85 Dec 27, 2007
    I have the same problem, interestingly it happened after I changed the settings on the power button to turn off completely instead of turning the backlight off when the power button is held down. Apparently some other people have been having that problem but able to power on by hard resetting or plugging in an SD card. Nothing has worked for me yet.
  • Anonymous Jan 07, 2008
    I have the same exact problem. Thanks for typing it all out so wonderfully. Did you get any help?
  • Anonymous Jan 25, 2008
    I have the samiler problem.
    I can't turn on the power of My I-mate PDA after I put it in my drawer for 1 month.
    I pressed power on button and hold for more than 30 seconds. Just couldn't turn it on.
    I tried to charge it from Adapter, Car charge and USB from PC. Looks like it can't be charged at all. None of them working.
    I bought it in September 2007.
  • Anonymous Mar 11, 2008
    I have the same problem with my X51V. I did not use it for about 2 weeks. I tried to turn it on, but it just showed the "Dell" picture in the very beginning for about 1 or 2 seconds, then turned off by itself. After tried the same thing for about 5 times, the "Dell" picture did not show up at all, just like no power. I did connect power adaptor to my X51v.
    I hope some one has a solution.
  • wcleong Jun 01, 2008
    1. Same problem. Sometimes can turn on with battery latch open warning and back to dead few seconds later. Suspect the battery latch cover micro switch problem. Anyone out there have any idea what's all this about? Help needed. Thanks.
  • lonenina Sep 09, 2008
    My PDA won't turn on whatever I do (Dell Axim x51). I charged it, held down the reset button and nothing. Any help or clue as to what may be wrong? I haven't used it for a few weeks but it seems to be charging appropriately. I need the programs on it. Help!
Hard reset the pda (poke the little hole on the back with a ball pen or something), it should boot up, on the bootup screen, it prompts if you want to reset to factory setting, answer no. lastly reset time when you get in.
Posted on Mar 19, 2008
Try to charge it for longer time, then try to turn it on, i'm not sure that its gonna work.
Posted on Feb 05, 2008
I made my I-Mate PDA-N working finally. I guess the key is to use original charger to charge the battery.
I finally noticed I used my Motorola cell charger to charge my PDA. It was working for long time, but not now. So I found my PDA charger and charged my PDA. Yeah! My PDA is back to work now. (The new battery I ordered few days ago is still on the way to my home :((((( ).
Posted on Feb 08, 2008
SOURCE:
I have just purchased a Toshiba Satellite C650D and we let the notebook battery dye fully. Now we can't seem to get it to start up. We did plug it in and still there is nothing. I am told by others...
If the battery is completely dead, it could take 5 to 10 minutes after you plug it in before it will turn on.
If it's in sleep mode, there should be a light indicating this and pressing the power button should bring out of sleep (or hibernation).
If none of this works and it still won't turn on even while plugged in, there is either something wrong with the laptop or the power supply and will need to be repaired or replaced. Try replacing the power supply first as that is the cheaper option.
Sep 08, 2011 | Computers & Internet
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
My Compaq Presario sr2050nx seems to always be running. The fans are constantly going and it seems the hard drive is always on. It won't go in to sleep mode or hibernation mode. The monitor will to to...
I recommend running a few programs to make sure that you don't have a virus, spyware or adware hiding in your system. Avast is a free anti-virus tool that is very effective. Super-anti-spyware is great for getting rid of spyware, and Adaware is a great anti-adware tool --- both of these are also free. Try downloading these programs (all 3) and run them on your computer -- this will likely get your system running like normal. Once you have run these, run a disk cleanup and defragmenter to get everything into tip-top shape.
Jun 02, 2011 | HP Compaq Presario SR2050NX PC Desktop
I have had problems with communication between the tower and the monitor. I recently bought a Dell flat screen monitor. The monitor worked for about two months, now when it is turned on, it immediately...
Sorry it IS the monitor this is a common problem, unfortunately, this is evidenced by the fact it still didn't work when connected to another machine,regardless of lack or message. Do a warranty claim.
Mar 05, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Laptop doesnt wake up after sleep mode activation
sound slike hard drive is going ...go into settings and turn off sleep mode and also set it to hard drive NEVER shuts off
Dec 11, 2009 | Computers & Internet
What do the controls on a portabel AC mean. Like the mode button.
my 4m40mitsubishi model have something nocking during a litlle accelerating in the acelerator
Oct 07, 2009 | Heating & Cooling
How do I turn off the sleep mode on a Dell MFP1815dn?
Hi there!
The printer's menu system should give you the option to turn off Power Save Mode.
Select Menu/Machine Setup/Power Save and the option should be available to turn off the feature.
This printer seems to have a reputation for causing headaches when waking up from sleep mode. Hopefully this will be your relief!
Aug 20, 2009 | Office Equipment & Supplies
Sleep mode
There is an On Display Menu (ODM). You can access it by pushing the button located on the monitor. Use +- buttons to navigate in the menu. Here you can switch off the sleep mode or change the sleep settings. I have a simular problem... I try to turn off the power save function but it seems like it dosen´t want to understand this...
Oct 08, 2007 | Compaq TFT5015 15" LCD Monitor
Imate jam PDA automatically switches off if not used for sometime
check your settings for "Power save" mode or sleep settings...else, look for a small pinhole to reset the device
May 28, 2007 | i-mate JAM Pocket PC
Dell Axim X51v Pocket PC Logo
465 people viewed this question
Ekse
Clive
Clive
