Question about Amana Dryers
No heat the dryer runs but there is no heat generated, just cold air
  • Mark Egan May 11, 2010
    If this is an electric dryer, it probably has a failed heating element, but you will need to provide more detail as to the problem, and what the exact model number of the unit is.
  • 979 Answers
Check the thermal fuse first. It is located under the top. It is pretty easy to get to. I assume you have checked the breakers and the wiring from the receptacle to the dryer itself.
Posted on Jan 28, 2009
Unit not generating heat -
More in likely heating element has failed and needs to be replaced...
Mar 04, 2015 | Heating & Cooling
Tumble dryer isblowing cold air only?
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying).
So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty;
Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct.
24642590-hf2jxxovvq5cn05mugly0fcq-2-0.jpg Dado
Jun 16, 2014 | AEG T58840 Dryer Electric
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
No heat in the dryer! The dryer runs and air has free flow to the exit vent but still not heat being generated
check on rear of dryer, as many have a small reset button for heater.If this is fitted then gently oush it inwards and this should solve the problem
Mar 08, 2010 | Dryers
Dryer works but is only blowing cold air. just bought the dryer last year and have already had it repaired once.
my Samsung was in a flood(so solution may only apply to floods), changed heater assembly, still blowing cold air, turned out to be the little black box on the generator, took box cover off,cleaned the connectors in box and voila...instant heat
Nov 28, 2009 | Samsung DV448AEE Electric Dryer
No heat on my Intellidry?
make sure the control is not set to "air fluff" - check your BREAKERS! if one trips, motor will still run, but no heat, flip them BOTH off and on several times, then try it. if that's not it, check the element and the thermal fuse
Aug 16, 2009 | Maytag PYE2300AY Electric Dryer
Dryer not generating heat and drying clothes...
Dear customer,
                We recommend you to do the following checks when your dryer isnt generating heat..
  1. Check for proper air flow
  2. Test the safety fuse
  3. Test the thermostats
  4. Test the centrifugal switch
  5. Test the timer motor
  6. Test the heating element.
Thank you.
May 09, 2009 | Whirlpool LEQ9858P Electric Dryer
There is only cold air in my kenmore elect dryer
The motor runs on 120VAC. The heating element requires 208/240VAC. Cycle the dryer circuit breaker. Other than a simple issue like that, the problem could be a bad heating element, thermostat, high limit control, thermal fuse, motor centrifugal switch, timer or electronic control. It can also be a wiring issue.
Apr 27, 2009 | Kenmore 62602 Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryers Logo
55 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
