Question about GE 25GT240 25" TV
DTV converter box needs specific channel
We currently recieve over the air channels on 3 & 4. What is the alternate channel to use to program box?
My GE tv, an older model, no longer works on channels 3 or 4 while hooked to my DVD/VHS player. I have to set my tv to channel 91 and I use the player to change channels.
Posted on Jan 28, 2009
Will our Sony Television Model No KD-28-~DX 40U work after the switchoverjanetgrant226@btinternet.com
No,as a tv alone only for recieving a free AIR DTV signal broadcasting signal tv channels.This tv is an analoge tv.U must hookup to any analoge tvs to a box that called a Digital Converter box to used to recieving free AIR DTV broadcasting signal for channels.U still can used it for any analoge tvs if u have a pay tv signal broadcasting channels services.
Sep 04, 2011 | Sony FD Trinitron KV-28FQ75 28" TV
Do you need a cable box for it
U mean a digital converter box for getting free broadcasting DTV airing channels?No,this tv it is a digital tv,just require a roof or a good digital antena.Hook it up with the antena and goto tv menu go to setup go down to Ch.pick AIR not CABLE and go into scanning for DTV channels after that tv will get all the free broadcasting DTV air channels.
Feb 17, 2011 | Toshiba 19HLV87 19 in. LCD HDTV
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Tried the RF Out setting and now Ican't reset it or even get the STB to respond to set up or anything.
If you changed the RF out channel setting on the DTV converter and now can't see the output of the converter try changing the channel on the TV set. THe DTV converter boxes are designed to output either RF channel 3 or RF channel 4. If you were on channel 3 and changed the converter output to channel 4, you will have to change the TV channel to channel 4 to see it again.
Hope this helps.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Do I need to get a digital converter box for the new dtv?
If you don't use an outdoor antenna then no, you don't need a converter box.
However some channels have to go through a rented digital cable box from your provider for some channels to be recieved.
Jun 01, 2009 | Televison & Video
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
ZENEITH DTT900 ANALOG TO DIGITAL CONVERTER BOX CONNECTIONS
Can't go through the VCR in the normal way. The DTV box must be tuned to the channel you want to record and left there. Cannot tell VCR to tape one channel and watch another nor tape multiple timed and multiple channel shows unless the DTV is tuned to that specific channel. This makes most VSR functions useless.
May 13, 2008 | Televison & Video
GE 25GT240 25" TV Logo
71 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
