Question about RCA RTD255 System
Playing CD'S When I install a cd in the tray, the unit goes to READING and never plays the cd, it will do this until it times out.
  • Ken Clark Jul 28, 2007
    I have determined the RCA RTD255 is a piece of crap, when I connected the speaker wires on the back, 3 of the spring loaded connectors fell apart, I have decided to buy a good Japanese home theater system and use the RCA system for target practice.
Nototh, My sister and have the same problem, with dvd's or cd's... it doesn't do it all the time, but it started after about 3 1/2 months after purchase, my sister's started doing that around 5 months. Someone replied that it could be overheating from over crowding with other components... but I have it sitting by itslef, so that's not it. I personally think it's the processor, because it "acts" the same as a computer "feeze up", so I think that it just doesn't have the right processor in it to handle the speed that it's set read at. But I stated that I'm no expert in that field. And it's going to cost more than the unit is worth to fix, so I just antied up and bought a Yamaha Amp & DVD high def/Klipsch surround combo, that I am very pleased with.
Posted on Jul 27, 2007
SOURCE:
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
CD Stops playing in middle of nowhere
Try cleaning the laser using CD Cleaner, if still won't work.You can cleaning it by your self( if you like !!)
The procedure is:
Open the CD case,by removing all the screw( unplug the power cord first).
After opened, see for the disc unit, it's mechanical unit, try opening it by removing the screw, unplug the driver cable unit and laser pickup ( very thin cables).
Then remove all the mechanical unit from the CD case, now open this unit by removing the top screw, then pull out the Disc Tray by rotating white gear under the tray.
Now you can see the lens, use a clean and soft clothes or cotton buds, use alcohol to clean the lens first, after using alcohol, use dry clothes or cotton buds to wipe it up again until the lens dry.
Resemble all back together and try operate it.
Hope it works!!!
Dec 08, 2009 | Audio Players & Recorders
American Audio Mcd-810 dual cd/mp3 player
i know its the tray belt.because,the same thing happened to me.my player would sometimes say error. or sometimes it would not read any cds.because,the tray would not close tightly.im shure its an easy fix.i did mine by my self.
May 31, 2009 | American Audio Mcd810 Dual Mp3 CD Player...
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Nov 30, 2008 | Integra CDC-3.1 CD Player
Cdn 36 pbm
unit needs internal cleaning. cleaning cd probably won't work.
Oct 27, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
Problem playing DVD's
bring (cd cleaner)cd from near radio shack and run it until you get good result.
Jul 05, 2008 | Panasonic SA-HE90 Receiver
Durabrand CD player skips while playing.
hi i've had the same problem i though it was the laser or the laser rail until i opened it!! Then i checked the laser, the rail and all the other mechanical it worked fine, until i got to the laser it had a hair right in the middle, don't bother trying the cd cleaner it doesn't work! all i di is take out the laser cleaned it with a cotton suabe and alochol for a bout a minute and now it works beautifaully! also clean the circle thingy that spins and holds the cd! any little particle will make that laser not read the cd right! while ur there tryin cleaning the unit from dust! it's the worst ememy! well hope this helps!
Feb 19, 2008 | Audio Players & Recorders
No sound when playing cd
What's cooking!? I too occasionally experience a similar problem with the RCA RS2042. When switching to the CD source, I receive sound from one speaker, while the other is faint. I have found that if you open the back and fotz around with the speaker connections (the system, not the speakers themselves), it will correct the problem. Have patience! Take care. -D
Oct 10, 2007 | Audio Players & Recorders
RCA RTD255 System Logo
49 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
