Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Stuck at setting up profile and can not get into advanced setup
I was or am having driver issues, but I think I have the right driver fo ME OS. I am still stuck at the profile and getting the usb to reconize mt wireless router. They are both Linksys and it has worked in the past. I reformated the harddrive on theis PC reloaded everything and now it will not reconize router, but works fine if I hardwire it.
  • 137 Answers
Check in the device manager for any conflicts with the driver ..like wrong one or a device with a ? there.. if it all loks good.. and you have the right driver for sure then.. manage your wireless settings.. configure it manually click the box.. then click connect even if network is not broadcasting... then make sure you have the right wep or pass key entered with proper ssid.. click apply... then give it a minute and should connect
Posted on Jan 29, 2009
My MSI U180 netbook resolution changed to 1024x768 after update and I cant see the lower part of my screen including taskbar. How can i revert to the original resolution ie.1024x600?
You do not say if you have tried to change the resolution yourself or what your OS is.
You can usually get to the resolution options by right clicking on a space on the desktop.
I have Windows 10 and right click > Display Settings and Resolution is right there.
You may have to Google for Earlier OS
Aug 09, 2017 | Acer Professional Computers & Internet
I have a new Dell OptiPlex 790 PC with 6 profiles on it. Whenever I try to open Internet Explorer, the page just spins and takes 5 minutes to connect. When I click on the MSN page, it does the same th
Hi Sirteryy,
What happens when you open MSN website with a different web browser?
What version of IE and what OS are you using?
You said "but none of the other PCs are having this issue."
Did you mean none of the other profiles? If not make sure this is not happening on the other profiles on that machine.
Make sure proxy is not enabled on Control Panel -> Internet Options -> Connections -> LAN Settings -> and 'Automatically detect settings' should be marked.
If nothing help try to restore advanced settings & reset settings to default on Internet Options under Advanced Tab.
Regards,
TheSmacker.
Sep 21, 2012 | Microsoft Windows 7 Professional for PC
"Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Jul 13, 2009 | Acer AL1916W 19" LCD Monitor
When i on my laptop the log on window start over
hi
i think there is a problem with the operating system
if it is windows and you have the operating system CD then set the bios settings to detect the CD drive as first boot device
insert the windows CD and let it go to the setup area
the first time it asks for the repair or setup select setup
next after it checks for existing windows setup OS and prompts for new setup or repair select Repair - R
this will reinstall all the windows OS again keeping all the existing settings as they are
hope this helped
cheers
pls rate the solution
Jun 28, 2009 | Acer Computers & Internet
Cash drawer problems
in the setup screen > in hardware section> select "USB printer" to open drawer
Jun 24, 2009 | Pc America Restaurant Pro Express
Speakerphone when answering blackberry pearl 8100
I have never a newer blackberry but on the ones, I had this worked for me. When you go into your profile to change them if you hit the menu button while you one of the profiles highlighted there should be a way to edit the profile, it could under advanced options. i hope this helps.
Apr 19, 2009 | RIM BlackBerry Bold 9000 Smartphone
Phillips SAA7130HL TV Tuner VISTA 64 BIT DRIVERS
well i had the same prob, so i downloaded drivermax, which I think is free.
drivermax scanned my computer and found all the drivers I needed including the vista philps tv tuner driver.
another way is to download iobit advanced system care which is an excellent free program and click the utilities button and then click drivers update. This should give you the philips driver as well.
hope this helps
it certainly worked for me
anyway you should be able to use the 32bit xp driver.
regards peter
Jan 23, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Epson R2400 too red
i think you have a corrupted driver- you have to uninstall driver first
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
Go to print and fax and delete the printer name as well
Restart the Mac. (You do not need to empty the trash.)
If you have not done so already, please follow the steps below to download the latest driver for your printer in OSX:
1. Go to the following website: http://support.epson.com
2. Under the PRINTERS heading select INK JETS and then the Stylus Photo R2400.
3. Under the DRIVERS & DOWNLOADS section select MACINTOSH.
4. Select and download the following file for your operating system
which mac are you using? tiger ot leopard? intel core or powerpc?
May 15, 2008 | Epson Stylus Photo R2400 InkJet Printer
Camera setup
Check your advanced wireless settings on your router, wireless mac filter might be enabled. Tou must allow the mac address of the wireless camera.
Good Day
Feb 24, 2008 | Linksys Wireless-G WVC54GC Network Camera
Lg ku250 modem driver
Download LG KU250 modem driver herehttp://www.ziddu.com/download.php?uid=ZaqblpymZbOZnJSlsKyZlJyiYq2WlZyt2
Oct 21, 2007 | Microsoft Windows Vista Ultimate Edition
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
69 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
