Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
My dishwasher is stuck on clean
I have a frigidaire dishwasher the digtal kind.it cleaned my dishes. after i opened the door it was still lit on clean so it wont do anything else I tried pressing the cancel button and it didnt work i also tried putting water in it so it can possibly restart itself I dont know what to do.
  • Anonymous Sep 09, 2008
    Just installed mine and I had the same problem after the first use. Cleaned the dishes, but had to reset the breaker to use again. It did it again the second time. Is it faulty? Is it a problem with the water temp not gettig hot enough?
  • jwilly81 Jan 07, 2009
    mine gets stuck on the clean position as well.  don't think it would be the element because it runs first then gets stuck.
  • 51 Answers
It could be stuck on clean because it is waiting for the water to reach temperature before continuing. If the element is faulty then it will sit there forever.
Posted on Jul 25, 2007
SOURCE:
Why is my dishwasher is stuck in the drain cycle
What kind of dish washer. It sounds like the switch is stuck try giving the dish washer a through cleaning.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Aug 13, 2014 | Samsung DMT400RHS Builtin Dishwasher
How do I clean dishwasher its starting to leave whiet spots on dishes
Good Afternoon Friend,
I understand you want to know how to clean your Frigidaire dishwasher, model# PLD2560LCC, as it is starting to leave white spots on your dishes. Please follow these simple instructions:
1. Load your clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes). The SENSING light will be off.
5. Unlatch and open the door and pour 2 cups of white vinegar into the bottom of your dishwasher.
6. Close and latch the door and allow cycle to finish.
Note: If these conditions persist, a home water softener should be considered.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire 24 in. PLD2560LCC Energy...
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
Frigidaire dishwasher 15 months old. just started not washing dishes very well. set it for high temp wash. put plenty of fresh dishwashing liquid in. the unit goes thru a full cycle. you open the door and...
First I would check to see if it is getting enough water. There is a screen in the water inlet valve that tends to pick up debris. Follow the links Dishwasher not cleaning starting with the video on the water inlet valve.
Nov 05, 2010 | Frigidaire Dishwashers
Detergent dispenser door will not open during the cleaning cycle. Dishes are not being cleaned.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 24, 2010 | Frigidaire 24 in. FDB636GF Built-in...
Dishes aren't clean, yet there's still soap residue in the cups
heatman101
May 09, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher doesn't wash dishes right
The solenoid that opens the detergent door may have had water leak into it. Remove the inner panel from the main door, remove the solenoid mechanism and it's core. With the core out, clean the solenoid interior and the core surface with hot water. The core should fall out of the solenoid by gravity if it is clean. DO NOT OIL THE CORE OR SOLENOID. If there are signs of water entry to the solenoid, check the detergent dispenser seal for damage. Try using a tab type of detergent rather than liquid or powder. Make sure the release mechanism is clean as well. Hope this repairs your problem!
Dec 29, 2009 | Frigidaire FDB1050REM Dishwasher
Dishwasher
Make sure that you do not open the door during the wash cycle. Wait until all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Mar 20, 2008 | Dishwashers
Dish washer frigerdaire, some dishes do not come clean
ck water level, a few min into wash cycle open door . make sure your water level is just below heater coil
Feb 24, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishes won't come clean
If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
349 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
