Question about Peg Perego Vespa Scooter
Tune up a Vespa
I would like to know how to tune up a Vespa
  • camarkim May 11, 2010
    It would help if you included what model and year your scooter is. I can give you a general idea for the pre-81 2-strokes, but the newer models would be a bit different. In general, though, you want to change your oil, your spark plug, check your tires (tread depth and inflation pressure), your lights (if you have them), and on the 2-strokes, check to see that the 2-stroke oil sight glass shows 2-stroke is full.
  • 41 Answers
That's like asking for the Holy Grail ! All i can suggest is to pore through the web and absorb all the ideas and suggestions you can. Save up lots of money while you are doing so. You're gonna need it. Dismiss the cheaper tips and tricks and buy as good a quality exhaust, carb and cylinder kit as you can afford. All depends on what you expect to achieve and how much you've saved. Every scooterist who has tried to tune a Vespa has their own favourites and recommendations based on experience. But every one is different as is every Vespa so these vary wildly. If i was to give you one big piece of advice it's this ......................Keep two fingers on the clutch for when it siezes !!!
Posted on Jun 21, 2011
What do I need to do a complete tune up on a 91 stealth 3.0 non turbo
Get hold of a good repair manual and do your homework!! Good luck.
Jun 02, 2016 | Cars & Trucks
Vespa ET2 50 Motorcycles carburetor tuning
Hi, Juan if you have changed your engine size, fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" you're not getting enough fuel.
1. Close to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. A wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, the engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Vespa ET2 50 cc Scooter Custom Performance Carburetor Carb Stage 1 3 Jet...
STEP 1 ADJUST IDLE MIX FASTER SCOOTER EPISODE 4
Carburator Theory and Tuning
VESPA LX 50 Workshop Manual
Vespa VESPA ET2 2001 Parts
Vespa LX 50 User Manual
Dec 16, 2017 | Vespa ET2 50 Motorcycles
Petrol,oil mixture for 1969 vespa 150 sprint with a px 125 motor
2% as most Vespas. Some folk like to add a bit more for a tuned engine.
Nov 23, 2010 | Peg Perego Vespa Scooter
I want to know how to tune my cobra 19 3 ultra cb so that i can recieve and transmit
you can't tune the radio. You must tune the antenna. I have a generic thread which explains everything you need to know about tuning your antenna.
See here. Hope this helps you.
Aug 22, 2010 | Cobra 19 Ultra II CB Radio
How to set the clock on 1995 Explorer XLT
Hi
Turn the radio on / press and hold the CLK button / press the right
side of the "SEEK" button to increase the hours or press the left side
of the "SEEK' button to decrease the hours / press the right side of the
"TUNE" or "TUNE DISCS" button to increase the minutes, or press the
left side of the "TUNE" or "TUNE DISCS" button to decrease the minutes
When the time is set - release the "CLK" button
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 31, 2010 | 1995 Ford Explorer
P0340 & P0341 CODES CAME UP THE OTHER DAY, I KNOW IT'S THE CAMSHAFT SENOR. I WAS WONDERING SHOULD I JUST GET A TUNE UP...I'T EXPENSIVE...$375
tune up wont fix it, need to have diagnosed before you have tune-up and i hope that tune up comes with plug wires for that price
Oct 17, 2009 | 2000 Cadillac DeVille
Manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
Aug 20, 2009 | Hitachi HL01453 Remote Control
Service engine light still on after tune up
I would have this vehicle scope tested to see which, if any cylinder is misfiring. A tune up WILL NOT necessarily eliminate any ignition malfunction, but a QUALIFIED tech will note a problem. Many factors can be involved in a MISFIRE, including, coils, compression, timing, and more. Hope this helps
May 18, 2009 | 2001 GMC Savana
Honda keeps stalling
You probably know this but... when you put it into gear you don't have your kickstand down do you. There is an automatic shutoff on the kickstand.
Feb 11, 2009 | 2006 Honda CBR 125 R
HOW TO TUNE GRUNDIG 14" TV
for tune your grundig you must use remote control
May 09, 2007 | Grundig GF70-600 TV
Peg Perego Vespa Scooter Logo
632 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
