Question about Canon DR-5060F Pass-Through Scanner
Lines all over second page
When I use the duplex, the second page has lines all over it. I can see that the scanner glass is dirty under the side you can not get into. I cleaned off the top and that is fine, but how can we get the glass off to clean the inside of the glass? Who can we take it to that can clean this?
  • 490 Answers
It is possible to clean the inner side of the glass. First you need to remove the scan module by removing two screws on each side, then remove the cable. Carefully take out the module. You will notice 4 small screws in the side, after removing which you can detach the LED module. Remove the vertical screws and this will detach the Lens Module. Now you will have access to the inner side of the glass. Ensure that the electronics, the Lens module and the LED are carefully placed back and cable connected properly. There is a small spring plate screwed along with the LED module, which needs to be placed properly. Please do not use any sharp instrument.
S. Mohan, Chennai, India
Posted on Feb 12, 2009
Scanning duplex I get a line down the righthand side of all alternate pages?
With very limited information, I suspect if you observe closely on the side that has the line printing you will find a dark smudge on the glass. If this is found you should be able to use a little rubbing alcohol on a clean cloth an remove the smudge.
Mar 28, 2016 | Fujitsu ScanSnap iX500 - document scanner
I have a canon doc scanner dr3080c When scanning on duplex ,the second page always has 2 parallel lines down it . I have looked to see if there is any dirt on the glass but there isnt What could it be
The dirt may not be visible, pls use Isopropyl Alcohol to clean the Glass surface. Don't use any solvents. For absolute emergencies, you can take aftershave/cologne on a cotton swab and clean the glass, ensure that plastic parts are not touched!
S. Mohan.
Apr 27, 2011 | Canon Office Equipment & Supplies
My scanned image has many thin coloured lines ruinning through it. It is not a dirty glass issue as the help page suggests
The mirrors in the optical system under the glass may be dirty or the lens near the CCD (charge coupled device) may also be dirty. This can happen over time. Dust gets in there and can cause this.
Dec 06, 2010 | HP ScanJet 3970 Flatbed Scanner
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Canon Dr2050C Duplex scanning reverse page all black
Check your brightness setting for backside. Ideally keep it automatic, else you can manually choose the right brightness.
S. Mohan
Sep 18, 2009 | Canon DR-2050C Path-Through Scanner
Getting vertical lines on scanned pages when duplex scanning on canon dr-3080c II scanner Only on duplex side of pages, though. Front page still shows up clean.
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Jul 10, 2009 | Canon DR 3080C Path-Through Scanner
A one inch line from top to bottom of page only on page 2
Its good you narrowed it down to 2nd side duplex. It has to be dirt on the glass of the scanner. Its possible that dust has gotten into the ccd or camera area. Take a flash light and see if you can see anything stuck which is black on the glass or if it has a scratch on the glass.
Jan 15, 2009 | Bell & Howell Sidekick 1400 Path-Through...
Line in the scaned pages
Morgansaki,
You have a dirty scanner lense. when you lift the top cover, as though you were going to do a copy from the platten glass, you will see there is a smaller glass to the left hand side of the scanner. look very hard at this glass and you will see there is a dirty mark on the lense. clean the cglass thoroughly with some quality window cleaner and you will find you line will go away.
Gremlin11
Nov 19, 2008 | Brother MFC-9420CN All-In-One Laser...
Duplex Scanning
If the line appears in the same location, it is definitely dust sticking to the glass. How thick is it? If it is thick, it may be because of an LED failed to glow, but this is etremely rare. If you are getting line in Duplex mode and not in simplex mode, it is on the second scanning module! Try cleaning with Isopropyl Alcohol (IPA). If you have been scanning old documents which tend to break like biscuit or get powdery, a speck can enter into the scanning area and create trouble.
S. Mohan
Oct 26, 2007 | Canon DR-2050C Path-Through Scanner
Canon DR-5060F Pass-Through Scanner Logo
131 people viewed this question
old marine
old marine
