Question about Panasonic KX-T7030 Corded Phone
Pick up receiver and get a dial tone for outgoing w/o pressing 9
1. I used to be able to pick up the receiver and get a dial tone. After a storm , I now have to press 9 or a CO. How can I go back? Found nothing obvious in the reference manuel.
2. Have changed to wire on handset but still have a lot of static with goes away if I hold the wire at the base of the handset very still. Do I need new handset or is there some adjustment?
  • jm1938 Jan 28, 2009
    I will try to figure that out. I see the program button on the system but not sure what to do from there.
  • lynn764 Apr 27, 2009
    I have the same problem but there was no storm. When the phone rings we used to be able to answer without pressing co line. How do I fix it?
  • 79 Answers
I beleive you are referring to a phone which is part of a PBX system or Key-system (sounds more like a Panasonic PBX system). If so, this is a system program that has gone "bonkers". You may need to re-program the automatic outside line dial tone on the system for the specific phone you are referring to.
Posted on Jan 28, 2009
  • Jinan
    Jinan Jan 29, 2009
    If you have a Panasonic PBX, please consult the Programming Manual or the engineer who programmed the system. It is not a user programmable feature but one for an engineer.
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
Sep 26, 2012 | Lands Phones
Please inform how to send a fax
well, I don't see your fax machine model, but typically...
  1. Place document to send in the input tray (usually top loader)
  2. Enter telephone number for receiving facsimile machine. If you are in an office, you may have to prefix the number with an 8 or 9, then country code. IE 9-1-555-555-5555.
  3. Then press Send (usually a green button).
  4. If it will not send, make sure you have dial tone. There is usually a handset on the facsimile machine which you can pick up to hear the dial tone.
Apr 12, 2011 | Canon Office Equipment & Supplies
Speed dial
1. lift the handset and listen for the dial tone. 2. press the store button 3. dial the number that you wish to store 4. press the store button a second time 5. press one of the numbers on the phone [0-9] and that will become the speed dial number. 6. make a record of the speed dial number and the name of the person it will call.
Then when you want the person on speed dial number 5, just pick up the receiver, get a dial tone and push 5. Thats it!
ps - kindly rate my answer as helpful. thanks
Feb 19, 2010 | Southwestern Bell Freedom Phone FM2552
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
Problem: Busy/No Response on all outgoing faxes
Put the document you want to send into the transmit tray, pick up the handset, listen for a dial tone, and then dial the # on the keypad..
It should ring just like any other phone. When the machine on the other end picks up and you hear the tones, press the start button.
Anything other than fax tones on the other end, it is not your faxes fault.
Nov 05, 2009 | Brother IntelliFAX 2800 Laser Fax
I have a GE phone, mod # 2-9223BKC. I want to program numbers in but i can't find the directions, can you help
MEMORY
Each memory button is capable of storing phone numbers up to 16 digits. Memory
locations 0-9 require you to press the mem button for access.
STORING A NUMBER IN MEMORY
1. Pick up the handset, and press the store button.
2. Dial the number to be stored (up to 16 digits).
3. Press store again.
4. Press a memory location button 0-9, and hang up the handset.
INSERTING A PAUSE IN THE DIALING SEQUENCE
Use the redial button to add pauses to a dialing sequence, for example after you dial
9 for an outside line. A pause is approximately 4 seconds long.
To change a stored number, you just replace it with a different number using the
procedure for storing a number.
DIALING A STORED NUMBER
1. Pick up the handset, and wait for a dial tone.
2. For numbers stored in memory locations 0-9, press the mem button, and then
number of the location in which the desired number is stored
Sep 15, 2009 | Lands Phones
Mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Jul 20, 2009 | Mitel 5212 IP Phone
Outgoing call does not connect when I dial the number
depends on the telephone exchange . Suggest switching to Tone signalling . MTDF - https://en.wikipedia.org/wiki/Pulse_dialing
Old technology- Pulse or Decadic Signalling - the line is broken by a relay contact or if even older a rotary dial manual switch contact - Dial a 9 you would break the line connection 9 times and send nine pulses.
Tone sends two frequency tones that encode the number that you selected and is a much faster dialing system and more modern method.
Oct 16, 2017 | GE 27906 Cordless Phone
Fax not going out/coming in
connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Mar 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
No dial tone
and does your line to your computer have one of the filters installed going to your modem line?
check your computers warranty here 4 FREE
Mar 18, 2008 | Symantec WinFax Pro 10.0 for PC
Panasonic KX-T7030 Corded Phone Logo
240 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
