Question about Canon PowerShot SD600 Digital Camera
Lens error restart camera
Lens stuck in, will not open, tried fresh battery, no luck
any suggestions would be appreciated :)
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 30, 2009
Lens barrel is stuck in the out position on my Canon Powershot SD1100 IS. Error message reads: "Lens error, restart camera". To my knowledge the camera has not been dropped and the barrel seems...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 20, 2011 | Canon PowerShot SD1100 IS Digital Camera
When camera turned on it says lens error and then shut down
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
My camera was stuck with an open lens and saying ?lens error, restart camera.? I banged it against my hand a few times, the lens retracted and all seems to work as it should now. Thanks for the post!
Dec 18, 2010 | Nikon Coolpix S3000 Digital Camera
My Canon PowerShot SD850 IS has a lens that is stuck in the extended position. I get a screen that says lens error, restart camera, but when I try to connect to the software, I get a screen on the computer...
Don't play around with that lens, you can do more damage to the camera and focus with some of the stuff people tell you to try. Your camera just needs to be serviced and you'll be working great again. The shop that specializes in service for the powershots is: camerasandparts.com They're amazing if you need a hand with one of these, that's all they deal with. They have your exact SD850 Lens Error, Restart Camera problem on their site. Good luck, they're the place for help with a powershot, best of luck with it.
Jun 23, 2010 | Canon PowerShot SD850 IS Digital Camera
My lens is stuck open, camera says lens error, restart camera. but it won't restart. pushed on/off button, changed batteries, switch modes no luck. any ideas?
There's some grit or dust in the lens/zoom mechanism.
Probably needs dismantling to clear. If you go to a repairer, get a quote first and check the value of your camera, make sure its an economically viable repair.
Apr 01, 2010 | Canon PowerShot SX100 IS Digital Camera
Canon SD1000 lens error
Turn off the Camera, remove the Battery pack, then press and hold the power button for 30 seconds.
Reinsert the Battery, then buzz around the lens for a few times then check if it works. Make sure that the Battery is fully charged.
The error message indicates that the lens is not able to adjust itself.
Oct 23, 2009 | Canon Cameras
Lens Error - Restart Camera : Lens remains in extended position.
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
May 28, 2009 | Canon PowerShot SD870 IS Digital Camera
Lens wont extend, lens error restart camera
My wife's Canon SD200 got stuck with an open lens and the E18 error. I opened the case and wiggled things and still nothing. Then, I turned the camera on and started tapping the edge of the lens casing with the magnifying glass I'd been using (need the battery and memory chip in place and make sure you've transferred pictures to your computer before trying this). Voila! The lens closed. But, of course, it wouldn't open and still gave the E18 error. Well, one good tap deserved another and Voila! again. It opened. After a few more iterations - and cleaning the lens casing each time, it was back to normal. The trick is the timing of the tapping. Just after turning on the power to the camera start tapping on the lens casing - not hard - just a light tapping. And don't tap on the glass lens itself -- you don't want to really break it.
May 15, 2009 | Canon PowerShot SD600 Digital Camera
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Apr 19, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
