Question about Xante CL30 HSE Laser Printer
Xante ilumina with error code 357
I think It has something to do with the waste toner bottle
jaylex
  • 417 Answers
SOURCE: We removed the waste toner bottle and it won't reset the error message
You will need to vacuum all the toner out as in the machine there is a sensor that looks through the waste tank and checks that it is clear. You can also wash the tank out then install it and you will not have the problem.
Thanks J
Posted on Jan 28, 2008
rooboy
  • 24 Answers
SOURCE: Xante Ilumina 512 error code
this error can be caused by a new or existing PC on your network. EXAMPLE: the network settings on new DELL pc's are default set to control the network and repair any conflicts..it seems dells dont like Ilumina's, and they get this error code.
Disable the network control function in the DELL settings.
And this error will not re appear until another dell is installed.
Posted on Jul 23, 2008
rooboy
  • 24 Answers
SOURCE: Xanté Ilumina: 020 fatal error
unplug power. open rear panel (2 thumb screws) check fitting of the ROM chips, restart..
020 relates to Slot A ROM DIMM
May need new ROM, or that CU PCB if unsuccesful
  • 95 Answers
SOURCE: error 357 waste toner full
If you dumped out the full waste toner bottle The gear that drives the gear on the waste toner bottle has broken off.
Posted on Mar 11, 2009
  • 15 Answers
SOURCE: waste toner bottle - Ricoh MP W2400
Just an FYI, this can be very messy. If you figure out how to get the thing out (should be near your consumable supplies like toner and image units) place the whole unit into a plastic bag, tie the bag, then shake it out gently. You may have to learn how it opens in order to "open the door". Best to use a vaccum with a heppa type filter as normal vaccum filter is too course for the fine toner partcles. Be ready for toner volcano.
Posted on Jun 09, 2009
How i can fix this problem 929:fatal error .
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
May 16, 2014 | Xante Ilumina Digital Color Press Printer
Xante fatal error 929
Feb 11, 2014 | Xante Ilumina Digital Color Press Printer
Waste toner near full
there is a white gear whre you install the waste toner box, that is connected to the box. see if it's broken - yoy will see the spring that is inside the gear
Sep 20, 2013 | Xante Ilumina Digital Color Press Printer
C9800 fatal error 145
Toner Feed Switch Error. Toner Lock Lever Open Error
145 = Magenta Imaging Drum
Mar 11, 2013 | Xante Ilumina Digital Color Press Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
Error code 0001900 for ir3300
The error code means the waste toner bottle is full. It may not be full, but once the waste toner bottle neck is dirty and the copier thinks it is full. It's a poor design from Canon. The waste toner is on the left rear side of the copier. It is behind a panel with one screw that holds it in. Remove the cover and remove the waste toner bottle and carefilly empity out the waste toner into a plastic bag. Make sure you clean the neck of the bottle. There are 2 windows on the neck. That is where it gets dirty. Return the bottle back into the copier & return the cover, Then turn the main power switch on the right side and turn it back ON and thats it... Good Luck
May 01, 2010 | Canon imageRUNNER 2200
Error 357 waste toner full
Dec 18, 2008 | OKI C9600hdn Laser Printer
Toner disappears!
ok, this issue is not toner related actually. the toner bottles you have removed, I am sure still feel the weight of a nearly full one.
The issue, is most likely, the Image Drum, the toner volume, is actually measured by toner flow resistance by a device within the Image Drum, I can explain it in detail, but will take a page..
toner cartridges, only have a chip transmitter in then, that tell the machine a code when it is first installed into the machine, this resets the toner volume processor only, then the yoner flow resistance inside the Image Drum signals the processor as to how the toner is travelling..
Replace the Drum, and then enjoy using all those almost full toners...
Aug 21, 2008 | Xante Ilumina Digital Color Press Printer
Jun 04, 2008 | Xante Ilumina Digital Color Press Printer
Xante CL30 HSE Laser Printer Logo
127 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Igor Studennikoff
Igor Studennikoff
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
