Question about Broksonic CCVG297 9 in. TV/DVD Combo
My dvd Player isn't reading DVDs. It is working for CDs and my Sega But just isn't working for DVDs. when ever I put one in it says that it is reading...reading...reading... reading...NO DISK!!! Please Help!!!!
  • 1 more comment
  • Khari Nov 01, 2007
    My DVD does not reeaad DVD. Message pop up " wrong disc" or insert disc"
  • Anonymous Mar 25, 2014
    DVD player does not work
  • Anonymous Mar 31, 2014
    no matter which way round you put it in it says no disk... please help
You need one CDclener & DVDclener go to the shoop end your problem is finys
Posted on Jul 26, 2007
SOURCE:
I got an Sony HCD S 300 Home Theater set recently. As I put in dvds and cds for playing, the dvd player says NO DISK. Thinking it is because it is not a original dvd it isn't working, I put another DVD...
It could be down to the Region of the Player or the Laser is Failing. As it doesn't play CDs then I suspect the the Laser is Failing (almost failed if it plays a cleaner but not CDs).
May 05, 2011 | Sony DAV-S300 System
Does not read Cds or DVDs
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
Nov 01, 2010 | Sony Computers & Internet
The unit will not play dvds but does play cds
shut it down and restart it. It has to do with the settings. Did You configure it when You first hooked it up?
May 24, 2009 | Philips DVD795SA Multi-disc DVD Player
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
Feb 18, 2009 | Televison & Video
Panasonic home theater sound system SC-HT720 won't read or play dvds or cds
mine does the same.the display flashes "prog" and --:-- on cd's,dvd's and even the cleaning disk it almost sounds like it isn't getting enough power to spin the disk.
Jun 23, 2008 | Panasonic Home Theater System System
No disc
The optical lens is out of alignment. This is why it will read CDs which have much larger data pits that DVDs.
The unit should be able to read and playback CDs (both production and burned) and DVDs (both production and burned). If the optics are out of alignment and exceed their tolerances, the player will not read discs.
This is caused fromt he player being dropped or jarred.
This is not an easy fix for the home user. This is something that a qualified professional needs to correct.
Jan 10, 2008 | Insignia IS-PDVD10 Portable DVD Player
My burned media from my new DVD Burner ASUS DRW-2014L1T isn't able to be read by my DVD Player
no data dvds work on the players.
use NERO 6 OEM to write Video DVDs or CDs they will run Players
Jan 07, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
DVD driver and handycam dvds
None at all - the DVD player has a chipset that is incompatible with that type of disk.
Check the player manual for the disk types it can handle
Dec 17, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Plays cds but wont read dvds
upgrade the firmware on the product.
Nov 10, 2006 | Sanyo DRW-1000 DVD Recorder/VCR
Broksonic CCVG297 9 in. TV/DVD Combo Logo
183 people viewed this question
Top Broksonic Televison & Video Experts
Marvin
Marvin
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
