Question about Honeywell Programmable Thermostat Heater
RTH2520B Honeywell Programable Thermostat wires
Had the thermostat hook up for several months and it worked fine. When I took it off to paint the wall, the wires came out before I could see from where. I have only a black and a white wire coming from the wall. I've tried all sorts of combinations of hooking these wires up again but none work properly: the thermostat makes the furnace heat its hottest all the time and the temperature stays between 79 and 81, even when I turn on the off button.  The choices of places to hook up the wires are labelled: RH RC W Y G Does anyone know what these letters stand for, if not where to put those two wires? Thank you.
  • soozankrayg Jan 28, 2009
    Thank you so much Tactup! The problem is now completely solved, and it's finally beginning to cool down in here.
    Best Regards,
    susan
    Novelist:
    Champion:
  • 230 Answers
Hi soozankrayg!
Your problem should be pretty simple. (assuming that it is a typical 24volt system) you should hook up the black wire to the "RH" terminal and the white wire on the "w" terminal. Make sure that you turn off the power to the furnace at the breaker or the furnace itself before attempting this. The reason for this is that you can cause a short and either break the fuse at the furnace or burn up the circuit board. This can happen very quickly and is very common when a thermostat is removed.
Posted on Jan 28, 2009
Honeywell com yourhome
Yes, it should work. Old thermo has 4 wires, follow instruction with new thermo.
Jul 22, 2014 | Honeywell Universal Digital...
How do I connect the two thermostat wires from a Honeywell R8184G4009 to a programable thermostat. My old thermostat is not marked.
On the Protectorelay Oil Burner Control R8184G4009, you connect the two thermostat wires @ "T" and the other "T". On the ACE Smart Temp Universal programable therostat, connect one wire to "Rh" and the other wire to " "W". Be careful if you are using this thermostat for A/C. In that case, make sure there is no jumper between "Rh" to "Rc".
Feb 02, 2013 | Honeywell Protectorelay Oil Burner Control...
I HAVE A HONEYWELL MANUAL THERMOSTAT NO BATTERIES ALL IT HAS ON THE BACK IS T8400C 1099 (2) 0710 1B HELP, IT DOES NOT SHOW ANY THING THE SCREEN IS BLANK
This model of Honeywell thermostat uses the 24v from the unit to power it. One of three things must have happened.
1. You have lost power to the furnace, therefore no power to thermostat.
2. You only have 4 wires hooked up on the thermostat and not 5. A lot of older homes had just 4 wire running to the thermostat, which will not work for this thermostat. You should have a wire connected to the (C) or (B) terminal on the thermostat, which ever one they have, I can't remember off hand. These are the Common terminals. They have to have the common from the furnace 24v power to operate.
3. Faulty thermostat, which will obviously have to be replaced.
Hope this helps and gets you to cooler days!
Jun 28, 2012 | Honeywell Heating & Cooling
Honeywell CT3611 thermostat, not working..
if you cross the two wires and you see a slight spark and heat comes on, then the problem is in the thermostat, if not then problem is at furnace it self.
Oct 24, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
I have just purchased a honeywell ct87n, could you please provide a schematic in order to connect it properly. I had someone install a honeywell digital thermostat several months ago, he did not tag the...
G to the manufactures webpage and type in model # and look upspecs . r- red y-cool w-white g-fan .. The red should be connected to rh--rc already by a jumper wire.
Sep 03, 2008 | Honeywell Heating & Cooling
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Honeywell 6300 programable thermostat instalation
The thermostat is a low voltage circuit (24 volts) most of the newer heating systems have a fuse for the low voltage controls. If you are having to re-set the high voltage circuit breaker, then you have something else wrong. When does the breaker trip? while its running or after it shuts off?
Nov 18, 2007 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
677 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
