Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
Replace the fuser for my Xerox 555 WorkCenter Pro
Do you have instructions on how to change a fuserr for this fax machine? I haven't purchased the fuser yet so what is the cost for a new one?
  • 239 Answers
To replace the fuser, the entire top cover needs to be taken off without breaking other plastic parts.
Extra precautions need to be taken when lifting the cover off once the screws are removed.
Once the cover is removed there are about two screws that need to be removed on the side. Electrical connectors pulled off on the left, without tugging them off hard. If one tugs hard on the fuser rod connector, the fuser rod can be broken easily
For this machine if they charge a flat rate for the call, and it covers the part, just place the service call and pay the fee.
It is not easy to do this repair job, and you can break other objects just trying to replace this fuser modual.
This may be well worth the cost if all parts are included with the service repair job. If the service call is placed to have the document feed roller and pad checked and or have them replace the document ****** pad while they are there.
Good luck.
Posted on Aug 12, 2010
    President:
  • 2,072 Answers
Google a business called The Parts Drop and give Britt a call, He can give you a price and most likely send you the directions.
If he can't provide me an E-mail address and I can type out the directions on how to change it. It not hard. I suspect the cost in the $150-$200 range.
Posted on Jan 28, 2009
4 Suggested Answers
  • 208 Answers
SOURCE: Fuser Error
You can also look for dealer service which is much more reasonable.
And also access secondary parts sources such as The Parts Drop online. Precision Rollers and several other sources.
Xerox will charge you an arm and a leg. There are many other sources to repair a 580 fax.
That is a very good product.
Posted on Nov 28, 2007
  • 2072 Answers
SOURCE: WorkCentre 555 Fax Drum
This will reset it for you. strange !!!!!
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode
Posted on Mar 14, 2008
  • 2072 Answers
SOURCE: xerox workcenter pro 765 error 22
That is a fuser not reachine tremperature fault.
Most likely the fuser will need replaced.
Go to google and type in "the parts drop".
Call Britt and he should be able to fix you up with that part for a fair price.Just tell him the model number and code.
Posted on Aug 18, 2008
My fax says replace drum, which we did, but it won't reset/restart. What is wrong? Is there a code we need to enter?
Yes there is a code, it has been so long I worked on these machines, need to find it.
I will come back later if I do find it and post it.
Jan 25, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
DRUM LIFE WARNING WON'T GO AWAY AFTER REPLACING DRUM.
find the box that the drum came in. There should be directions to reset the drum light enclosed. Or go to www.xerox.com , then look under support and drivers. Good luck !
Jan 11, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
I change Drum On work center pro 555 Fax Be cause it told me it was low but i cant clear the warning message off the fax i shut dowbn and rebutted but nothing can you help
Drum units usually have an electronic counter that have to be reset through a sequence of key strokes on the number pad. Your local dealership should be able to give you the info to clear the drum counter
Oct 17, 2009 | Xerox Office Equipment & Supplies
Right side of Print Out is faded. Cleaned, and Cleaned. Doesn't say to change drum/ink. What else can we try?
You can try shaking the toner cartridge to even out the toner but most likely either need a new toner cartridge or the drum is not sitting evenly as it should.
Sep 11, 2009 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
We get a communication error to one specific fax #.
One of you has likely changed their fax machine/system recently, and simply put, some machines do not 'play well' with others. There are some DEEP programming changes that could be adjusted by a tech, such as "baud rate", etc. but for one location, it's not worth it.
Jun 05, 2009 | Xerox WorkCentre Pro 555 Plain Paper Laser...
How can i get it to print on both front and back sides of the paper
You will have to turn the paper over and run it through the Fax/printer/copier to do the second side. The drawback to this is that you will coat the Fuser with a layer of toner contaminating the rollers resulting in what is called offsetting. IE repating of image from the previous print. Resulting in replacement of the fuser this is not a user operation and will result in a service call about 300 + parts. I do not recomend second side printing on this model.
Dec 30, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Xerox workcenter pro 765 error 22
Aug 18, 2008 | Xerox Office Equipment & Supplies
    1. Yes
    2. No
Mar 14, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
170 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
