Question about Icon Image 17.5 S Treadmill
Image 15.0 Q treadmill
The treadmill is plugged up to a surge protector, it has worked fine. The power is on in the front, when you put the magnetic key on, the lights come on the machine, and then go off in 1/2 a second and there is no power to the machine. I have taken the front cover off and you can see the power light is on, but the actual machine at the top has no power to let you get started on your programs. Any ideas????
2 Suggested Answers
  • 4 Answers
SOURCE: there's power but the machine itself won't work.
Hi, check if it is possible: main fuse in electronic board, normally all the board has a small relay, so when treadmill is on 4 or 5 seconds relay sounds with a click, if you press start and treadmill doesn´t move could be a problem with PMW circuit, MOSFET, Diode, diode zener and small transistors.
Best regards.
Posted on Nov 05, 2009
Power surging
sounds like the treadmill is drawing too many amps. try using a larger surge protector.
Feb 19, 2014 | Nordic Track NordicTrack C2300 Treadmill
I have the pro-form 980 cs and the screen displays a bright blue color but no words on the display. It was working fine, but a storm over the weekend knocked out our electrical power. It has not worked...
Dear Friend:
Thank you by your request.
I will try to help you inmediately:
nstructions Things You'll Need
  • Phillips screwdriver
  • Allen wrenches (included with the Proform 980 and Proform 980CS)
  1. Power
    • 1 Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
    • 2 Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
    • 3 Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 98CS and a horizontal switch on the 980 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
    Reed Switch
    • 1 Unplug the treadmill and remove the safety key.
    • 2 Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 980 Interactive trainer and four screws on the 980CS.
    • 3 Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
    • 4 Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
    • 5 Reverse the directions to put the hood back on and the treadmill upright in the original position.
    Optic Sensor
    • 1 Unplug the treadmill, take out the key and remove the hood cover.
    • 2 Locate the optic disc and optic sensors. The optic disc is the only circular disc set between two optic sensors.
    • 3 Spin the disc with your hand. It must spin without hitting either of the sensors. Loosen the adjustment bolts that hold the switches in place with the included Allen wrench and adjust them to ensure they do not interfere with the discs' ability to spin. Tighten the bolts and replace the hood
    Thank you in advance, sincerely. Blessing.
If you need additional Help, please reach me.
Sep 28, 2011 | Proform 980 CS Treadmill
I have a Reebok Vista treadmill that has NOT been used that often. We turned it on the other day and the only button that worked is the start. We could not change the speed or the incline etc. Any ideas...
Dear Sir:
I will help you inmediately: Check the circuit breaker to see if it hastripped. If the reset/off circuit breaker has tripped, wait 5 minutes andreset.
    • 2
If the power cord is properly plugged in, unplugit and wait 5 minutes before plugging it back into the surge protector.
    • 3
Remove and reinsert the console key. 4)Remove the key from the console and UNPLUG THE
5) Next, remove the screws from the hood
and carefully remove the hood. Locate the Reed Switch
and the Magnet on the left side of the Pulley .
6)Turn the Pulley until the Magnet is aligned with the Reed
Switch. Make sure that the gap between the Magnet
and the Reed Switch is about 1/8". If necessary, loosen
the indicated Screw , move the Reed Switch slightly,
and then retighten the Screw.
Re-attach the hood and run
the treadmill for a few minutes to check for a correct speed
Thank you in advance,blessing, if you need some additional assistance please reach me. sincerely.
Managua, Nicaragua. C,A
Sep 13, 2011 | Reebok Vista Treadmill - RBTL13305
I have a proform 300 treadmill. we moved into a new home and it just stopped working. it was perfectly working before the move. now, nothing comes on, no power, nothing.
Dear Sir:
I will help you.
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
2) Circuit Breaker:
Please check the circuit breaker from the main panel, and reset, or put some Lamp for to see if turn on. if do it. the problem could be the wires and the plug, Test it with A VOM(Voltimeter) for a continuity.
If you need extra help, please do not hesitate to reach me. .
Sep 13, 2011 | Proform 810 TR Treadmill
When I turn on the treadmill, the top console lights up, but the bottom half of the console won't work except for 2 buttons. The START button will start the treadmill at 1 mph (stop will not...
First of all you need a Surge protector, you can get one from, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Jan 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
The power is on but it won't run
Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Thanks for the rating Good luck
Dec 22, 2010 | Exercise & Fitness
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Aug 21, 2010 | Exercise & Fitness
I purchased a reebok s9.80 from sams club,most all the paperwork and wrences were missin. how can i get info on this particular model?
I just bought the same thing from sams club and am having the same problem.....I can't even get mine to turn on! Can anyone help?
Feb 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Icon Image 17.5 S Treadmill Logo
252 people viewed this question
Top Icon Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Alienware X51
Alienware X51
Level 1 Expert
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
