Hello, my amana heating and cooling will not turn. the outside(a-c unit) will turn on for a couple of minutes than shuts down. upstairs, the furnace will not turn. can you help?
    President:
  • 1,214 Answers
Please give the model number, is the furnace gas or electric, and is the system a heat pump (which that can be determined by the model number.)?
Posted on Jan 28, 2009
Have amana furnace model GACA070AX30. FURNACE HAS A 5 FLASHES ON ERROR CODE. FURNACE STARTS UP REACHES THERMOSTAT SETTING, BURNERS SHUT OFF BUT FAN MOTOR WILL NOT SHUT OFF. IT ALSO TRIPS ROLLOUT LIMIT
This is a dangerous situation. If your rollout is being tripped open, the heat is going where it should not be going. The fan stays on because it is designed to dissipate the heat.
Nov 03, 2017 | Amana Heating & Cooling
We have an amana ac. It recently started making a loud noice from the furnace closet which is upstairs. 2 different ac repair companies came out but could not find anything wrong. The line to the outside...
Hello, if the line is freezing there is either a airflow problem or low refrigerant charge. If there is a loud noise most likey the bearings on the motor or the blower wheel is bad and causing a lower amount of air passing over the evaporator coil and thus the freezing of the suction line.
Jul 15, 2012 | Heating & Cooling
Bryant furnace model FX4C, FY4A with heat pump and a/c will not switch from a/c to heat pump. Only have heat with emergency heat on.
WELL this could be a couple of problems the reversing valve could be stuck either from not enough pressure which would be a leal and low on freon or the unit is off on low pressure switch/high pressure switch from either being low on freon or something restricting it and caused unit to shut down, ive been a servicer for many years and if it gets below 30 degrees outside i would recommend running the e-heat anyway it does cost more money minute for minute. but you will find it will heat alot faster in those colder nights than the heat pump therefore cost is about the same.
as far as not switching over could be low on freon or a stuck reversing valve... is the outside even running in cool mode if not the you may have a tripped pressure switch...good luck
Jan 04, 2011 | Bryant Heating & Cooling
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Not cooling
every single component in your cooling unit is needed for it to work, so anything can shut it down. If you could provide more information as to what type of unit you have: is it a central heat and air package unit? or central split system (furnace indoors and condenser outside)? or a wall a/c? Does any part of the system/unit do anything?
Apr 27, 2008 | Heating & Cooling
Janitrol Heat Pump
Jenny,
Sounds to be a system freon leak. The unit and the stat talk to each other and if the temp is not reached and the unit shut down in a set amount of time it turns on the E-heat. Now there are other facts that could be involved, plugged filters, dirty coils inside and out, etc. Check your filters first to eliminate that problem.
Apr 11, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
