Question about Zanussi IZ12 Front Load Washer
Zanussi IZ12 Washer won't spin.
Washer won't spin. Have laid washer on its back (which seems to put lowest strain on seal) and have checked belt (which seems tight). Looks like motor is sealed unit. Sounds like it attempts to spin but nothing happens. Motor and drum turn easily by hand. Draining and then turning on/off allows us to empty it. Any ideas on how to test if its the motor or the control to it or any other ideas would be much appretiated.
  • Rob Savage Jul 27, 2007
    Brushes removed and awaiting replacements due tomorrow. Thanks again.
  • 38 Answers
Check the motor carbons they r mounted on either side of the armiture you will find they r held on the motor with 2 screws or 2 5.5mm nuts make sure you unplug the machine before u start working on it good luck
Posted on Jul 24, 2007
  • peter cann Jul 27, 2007
    you r welcome thanks 4 the feed back
Machine retains water
Please check the small thin rubber pipe that is connected to the drum. it acts as a pressure sensor may be it is clogged and not able to give proper water level reading. use skewer or thick flexible wire to clean it.
Oct 03, 2017 | Zanussi IZ12 Front Load Washer
How do i change the drive belt ?
To remove the belt use a long screwdriver. Put it between the belt (sideways) and the large wheel, lever the screwdriver to outside while moving the wheel in clockwise/anticlockwise depending upon where you put the screwdriver at left/right side. Reverse the procedure for putting the belt on the wheel. While putting the belt first fit it on the motor pulley.
Sep 18, 2011 | Zanussi IZ12 Front Load Washer
When i press the start button the light above it is still flashing and the machine will not start.
Don't know the model but I would check the front door seal and then the switch . The switch is a safety and won't let it spin ,fill or any thing check out the switch to seee if works
Mar 28, 2011 | Zanussi IZ12 Front Load Washer
After wash clothes come out after wash they have dirty specs
if machine is noisy in spin cycle suspect faulty bearing seal. replace seal and bearings
Jun 30, 2009 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Feb 15, 2009 | Zanussi IZ12 Front Load Washer
Washiing machine will not spin.
Check outlet pump.Clean and try again.Jan
Jan 31, 2009 | Zanussi IZ12 Front Load Washer
Where can I order a new belt for my Zanussi IZ12 wasmachine?
bit of a nuisance doing it from afar but i have used currys masterpart ( a uk site) for ordering spares now i'm retired
Nov 12, 2008 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 Pumps, then Pause LED is flashing.
Remove the power cable for few hours and then try again. Good luck!
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Zanussi FLE 1015W
Any solution yet ? same problem here Zanussi IZ12
Zanussi IZ12 Front Load Washer Logo
175 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
