Question about InFocus Proxima UltraLight DX2 Multimedia Projector
My Proxima Ultralight DX2 shuts down after 5~10 minutes
I have a Proxima Ultralight DX2. My unit also shuts down after 5 to 10 minutes - green LED lamp blinks slowly. The intake & exhaust fans continue to run for about 1 minute. Changed lamp but still the same problem. To restart, I must turn off main switch then back on & the same thing happen again
tinamarie49
  • 34 Answers
SOURCE: Proxima Ultralight Projector 350x
The filters probably need cleaning. Also check and make sure none of the vents are being blocked.
Posted on Dec 05, 2007
SOURCE: InFocus Proxima UltraLight LS1 LCD Projector
needs a new bulb
Posted on Dec 21, 2007
SOURCE: drivers available
You can download all the information you need from:
http://www.askproxima.com/service/m3/m3.asp
Jason
LCMA Insurance
http://www.lcmainsurance.com
Posted on Jan 12, 2008
  • 3422 Answers
SOURCE: lamp didn't strike
lamps are affected by strikes. each strike erodes a part of the anode. so in essence, the lamp wears out. However a Xenon has a much longer hour life as once it is running, it cares "relatively" little about how long. SO for commercial units, this is an advantage. there are also larger potential issues about colour stability over life.
with UHP, they care only minimally about strikes, it really is not even a strike, so while frequent on and off can kill it early, with normal usage, you are going to be fine. However with a UHP, if a lamp runs for longer times... then you have issues. THe way i had it explained to me was as such;
With a UHP, it gets up to proper operating temp in about 5 mins. once it is there... it SLOOWWWLLLLLYYYYY continues to heat up. After about 2-3 hours, it starts going outside the nominal operating range. once it does so, it starts to degrade the lamp. thereby lowering life expectancy. if you shut it off after about two hours or so and let it cool for ten mins then do it again for two hours... you are in a much better place. In a grand scheme, apparently if you run the proj for an average of 4-6 hours every time, then expected lamp life goes to about 50%. THis is very rough and in a general sense so just take it as general guidelines.
TIPS TO EXTEND PROJECTOR LAMP LIFE:
Lamp life for a projector will vary based on many factors including application, installation, intake of cool air and exhaust of hot air, usage, and proper maintenance. Heat buildup can reduce lamp life and even damage your projector. Here are some tips to help your projector lamps last longer.
Once you turn on your projector, wait at least five minutes before turning it off to allow the fan to properly cool the unit. After the fan has cooled your projector, you may unplug it and store it as desired.
Do not obstruct the air intake or exhaust vent. Paper should not be placed on top of a projector, or where vents are located.
Keep the exhaust vent at least two feet from any object.
If the projector is built into a compartment, wall, ceiling or shelf mount, the minimum distance requirement (usually at least two feet) stated in your owners manual must be maintained.
Clean the projector's air intake filter every three to six months -- or more frequently -- based on your operating environment.
Do not move your projector until the lamp has cooled (about five minutes).
Run your projector for two weeks and/or 20 hours shortly after your purchase. If the lamp is going to fail, it will usually occur within the first ten hours of operation. Lamp warranties typically last just 90-180 days from the date of purchase, rather than the first installation.
When you purchase a replacement lamp for your projector, remove the existing lamp and use the old lamp as your spare. If your projector is new, test the original lamp for the two weeks/20 hours before removing and storing as a spare.
I hope the info. which i have given you solves ur problem if not i am sad to say you have to get it repaired..
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 11, 2008
Marrie
  • 563 Answers
SOURCE: proxima ultralight projector won't project when I hook it up to my PC
Just get your PC settings right and Bob's your uncle
Posted on Apr 01, 2008
I have power to my Proxima ultralight LX2, the ready button is green and the lamp is red. The machine will power on for a short time and then power off with a flicker of light from the bulb. I am...
It sounds like you should check the lamp to see if it has too many hours on it. The bulb should look pretty clear & round without bulging & dark spots or fogging. If it has a lot of hours it needs to be replaced. It may also be a fan that is not turning on or is not turning fast enough. Use canned air & while unplugged spray the fans to make them spin fast. You can use a flashlight to try & locate the fans behind the vented areas arount the case. If a fan is not working properly it will cause the unit to shut down. Also check your indicator lights on top & compare with the troubleshooting portion of the user guide. You can get a user guide download from google search.
Good luck,
Jim
Apr 14, 2011 | InFocus Proxima UltraLight LX2 Multimedia...
Can't get lamp to fire up. Fan and panel green lights go on, but lamp won't . Replaced lamp but still not light. Green Panel light blinks green. Any suggestions on repair?
Hi, did you remember to reset your lamp timer after replacing the lamp? You can learn how to reset it on this LINK....
If after resetting, the light still remains green, then it's either the color wheel motor is not getting up to speed to sync with the dmd chip, the wheel sensor is going, or the power supply needs replacing. you can try to replace them yourself or send it to an infocus authorized service center....
Jan 15, 2011 | InFocus Proxima UltraLight DX2 Multimedia...
My computer is not connecting to the projector, how do I resolve this issue?
Replace the cable with a new one---brand new. reflash the software. if that don't work, it's the main board.
May 18, 2010 | InFocus Proxima UltraLight DX2 Multimedia...
I have a proxima s540 ultra lite data
From what you describe, it sounds like a fan isn't working. When you turn on a projector, it will go through a quick self test--checking that everything is operating correctly. Some of the fans send out a signal to the main board telling it that they are running. If no signal is received, the board senses this and auto-shut down occurs to protect the unit from heat damage. The errant fan could be spinning but the computer pulse might not be being generated. It will require a tech to find this out.
Aug 31, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
Infocus X3, no light, LED is solid green.
the colorwheel. if it does not spin, the lamp will not light.
Aug 26, 2009 | InFocus Proxima UltraLight X350 Multimedia...
My Proxima Lx2 has a bulb issue
Hi there
You have to reset the lamp timer.
Should solve your problems.
Mar 31, 2008 | InFocus Proxima UltraLight LX2 Multimedia...
Proxima Ultralight x350 no valid input source error?
reset the settings to factory default. if that doesn't work, the lamp may not have enough power to stay on. if the lamp doesn't have many hours on it, it's the ballast.
Jan 05, 2008 | InFocus Proxima UltraLight SP1 Multimedia...
Missing video module
you'll need an adapter. dvi-svid or a dvi-vga and a vga-svid.
Jan 02, 2008 | InFocus Proxima UltraLight DX2 Multimedia...
InFocus Proxima UltraLight DX2 Multimedia Projector Logo
77 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
