Question about Samsung HP-S4253 Television
Taking US Samsung TV and DVD player to India?
Can I take my Samsung TV and DVD from the US (110V) to India (220v)? What do I need? I was told that in addition to a step down converter I need to check about NTSE vs PAL systems, etc. Please help.
  • 98 Answers
You need to get a transformer( 110 to 220).
Posted on Feb 06, 2009
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
Can I plug GE dryer GTDP250EMWW directly to 220v? the manual says that the power rating of this model is 110/220v.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
Sep 06, 2012 | GE Dryers
I have puchased UN40D6300 samsung led tv from US to india. but it is not working in india with TATAsky hd setup box. STB generating output on 1080*50hz. its giving "the resolution is not supported...
hi,
Check whether the tv's ac input voltage. if it is 110V then it is made for US users only. It will only work with NTSC colour system. Here in India the colour system is PAL.
OK
Sep 15, 2011 | Samsung 40 UN40D6300 LCD TV
Can i use philips hair straightner hp 46666 from canada in india
yes definitely u can use...
Please refer to user manual for power rating...
In India the voltage used is 220v whereas in Canada its 110v
some machines can work in both the voltages...certain do not...
In this case you can use a voltage converter to convert 220v to 110v...
Feb 10, 2011 | Philips Computers & Internet
Plugged to wrong voltage
first thing to do would be check the fuse that is usually in line to the transformer hope this helps regards JIm
Apr 29, 2009 | Sony SLV-D370P DVD Player/VCR
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
MY PANASONIC BD30 BLU-RAY PLAYER WILL NOT PLAY ANY BLU-RAY DISCS IT WILL PLAY DVD'S AND CD'S
i bought new panasonic bd player bd30. thugh amazon (us). it is not at all reading any disc. i brought to india ithout box. i am using 220v to 110v converter. here it is loading but not reading any bd disc nor region 1 dvds , please help me to solve the problem. it is also new one. rajkumar ( supja46@yahoo.co.in)
Jul 19, 2008 | Televison & Video
WA71N2 plugged to 220V should be 110V
The Fuse for these model is 110V - 250V, so definitely the machine will still light up for a moment then black out. So if you accidentally plugged it to 220V (if it is 110V) you have to change the whole PCB. Electric current are distributed by PCB which only handles 110V.
I suggest when you change the PCB try to change also the Fuse to 110V only so that next time if by accident it was plugged to 220V you just have to change the Fuse not the PCB.
I
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
110v - 220v power short problem
No major worries. Only "Fuse" would have gone. You can get this replaced with some good electronic repair shops. Might charge you around Rs. 100 (else Rs. 500 since it is a "US return" item :) )
Mar 08, 2008 | Panasonic SC-HT895 System
Televison & Video Logo
166 people viewed this question
Henry  Thomas
Henry Thomas
