Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore 106.71299100,water freezes on floor of freezer,drain line freezes,I have opened drain with hot water etc.then problem returns in about one month. the refrigerater is 6 years old and this problem is intermintent over past year.
  • 135 Answers
You have a partially plugged drain, causing water to flow too slowly. Try reaming out the drain with a long stiff wire until water flows thru it like a faucet. You may have to unplug the unit for a day to get every part warm enough. Hope this helps!
Posted on Feb 16, 2009
Condensate drain inside of freezer compartment keeps filling up and freezing and then overflows to bottom of freezer compartment and freezes. Have made sure drain line is clear. Problem occurs about every...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
If you need more help GO HERE:
Thanks for using fixya
Leo Ponder
Sep 22, 2011 | Kenmore Side by Side Refrigerator
Leaks water inside from the ports or vents under freezer but in fridge
Your problem more than likely is a plugged defrost line in the freezer...The freezer goes through periodic defrost cyles to keep the coils from freezing up. The water catches in a trough pan in the freezer and flows through a drain hole to the bottom of the fridge where it evaporates. This drain hole perodically freezes up and the water accomulates under the freezer bottom until the water level reaches your vent ports to the fridge section. Open your freezer and on the bottom floor of your freezer you should see two screws near the front on either side. Remove them and then take out the bottom tray....this will expose the drain hole near the rear of the freezer compartment. You will more than likely have to remove ice under the tray in order to see the drain hole. Remove the lower back panel on the back of the refrigerator and you should be able to see the drain line coming from the freezer. Unplug the refrigerator before you begin work. It will take a little while for the drain line to thaw to allow liquid to flow to the bottom. I find a hair dryer pretty handy in speeding up the process. To verify you have unplugged the drain line you should be able to pour hot water in the drain hole in the freezer and see it come out at the rear of the fridge in tube line just above a little catch pan
Feb 08, 2011 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Elite 795.75542401 Water freezes on the bottom & then spills out to the floor. We can't find a drain hole anywhere!!
There is the drain in the freezer under the evaporator. You have to remove the rear panel in the freezer and the freezer floor to access it. Defrost it using a hair dryer and put hot water through the drain to make sure it's clean. Make sure the bottom end of the drain hose (behind the rear cover) is clean as well. Vacuum everything in the compressor compartment and keep it clean.
Please check the useful links bellow related to your query...
Let us know if you want something else please accept the solution.
Sep 20, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer door is leaking water at the bottom of the door
This sounds like the defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle.
If you can see ice on the bottom of the freezer floor, then this is likely your problem unless your ice maker is leaking from the top of the freezer.
Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Kenmore colspot freezer drain line keeps freezing
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Jul 17, 2009 | Refrigerators
Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Jun 02, 2009 | Refrigerators
Water freezing up in the bottom of the freezer
your defrost drain is stopped up then when it defrosts in steed og going down the drain its running in the freezer floor remove the back panel in the bottom of the freezer and clear the drain hole under the evaporator
Mar 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
174 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
