Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore Electric Range Slide in....beeping while not in use
Kenmore Electric Range Model # 790.46991 mfg. 9/2001 Oven started beeping while not in use...F9 error. Tried cutting power while pushing cancel....door locked...still F9 error and beeping. Tried this 2nd time and oven started heating on its own...so I cut the power off. Surface units work fine, but the door is still locked. Pulled unit away from wall and discovered it is hard wired into the house! NO PLUG!  Sears did the install......why would they do this? Help please!
  • 979 Answers
Hard wiring is O.K. and really better because you don't have to fool with the plug and the loss of or poor connection there. You can just turn the power off at the breaker. Without knowing what the F9 error code is, you may have a problem with the board inside the control panel. To get the door open, try to push and hold door closed at the same time. This may loosen the tension on the closer and allow it to open. Pull the lever to open it. If not, try to moderately tap on the door where it latches and it may open then. Next, slide a thin screwdriver into the latch and free it up there. Once the door opens, I believe your oven will work. The oven believes it is in the self clean mode. When you get the door open, turn on the oven with the door open and it should heat. If it does not, check the wiring in the back and you may find that one of the wires has burned off the control switch for the oven. I know this sounds like a lot, but it should save you a tech call and a couple of hundred dollars. Hope this helps.
Posted on Jan 30, 2009
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 | Ovens
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Error f1 and beeping sound when the oven is on. Heating non stop.
Your digital panel may still be under warranty. It may be worth your while to have a tech look at it. Something else is going on here.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Beeping sound and f8 displayed
F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
May 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
231 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
