Question about Sansui HDLCDVD220 22 in. LCD TV TV/DVD Combo
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get cable or a roof antennae, but we can't afford it. Is there another solution?
  • lgreges Jan 28, 2009
    The rabbit ears are brand new. The cable is not flat, no converter used.The antenae has 2 dials on it ,I suppose for range and its set to the highest. I don't know if that makes it an amplified range. Incidentally, the tv is on the 3rd floor and there are other tall buildings around. Thanks for any advice!
    Sergeant:
  • 227 Answers
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Posted on Jan 28, 2009
  • Mike Schmidt
    Mike Schmidt Jan 28, 2009
    Thanks, that info helps. Have you checked to see what the tv is set for on the antenna listings? You have a choice for cable or standard (outside/rabbit ears). If that antenna worked and is new then we have to point our finger at the tv. Let me know how this works. Do not forget the paper clip trick to see if you get a better picture, you can just hold onto it.
I have cello TV and now no channels . have tried factory reset and still shows message as Database empty. What can you suggest?
To Get free broadcasts you will need to 1) have an antenna and 2) run the Channel Scan or Auto-TUne program. Any antenna will work - Rabbit ears etc. Once connected you need to go to setup and run the channel scan - it will find the digital channels in your area and load them into the database. You can get an antenna at Radio Shack, Meijer, Kmart etc. any place they sell TV's. Like I said even the old Rabbit Ear antennas work fine for Digital TV.
Jan 15, 2015 | Televison & Video
Can I use an antenna on my sharp tv catv? If so, what kind works for this tv
Hook up your rabbit ears and auto tune the TV and see what happens.
Jul 24, 2012 | Sharp Televison & Video
What type of antenna do you reccomend cant get the tv to work at all no picture no sound not using cable no antenna tried auto PLEASE ADVISE!!!!!!!!!!!!!
Lets get started. First the TV you have does not have the new ATSC digital tuner built in. It uses the old NTSC tuner. You might find a few stations, however most major networks have gone Digital because the maximum power for NTSC is limited to 1000 watts. ATSC is the new digital standard for broadcasting both High Definition programs as well as standard definitions programs. So you will need a Digital converter box. They sell them at Radio Shack for around $60. You can get one on ebay for around $25. You will also need and antenna. A good old set of rabbit ears will work fine if you not to far (less than 25 miles) from the transmission towers. If your out in a rural area (greater than 25 miles from the tower) you may want to consider and outdoor antenna. Antennas Direct is a great source for antennas.
http://www.antennasdirect.com/
You can also get help estimating what kind of antenna you need at this web site:
http://www.antennaweb.org/aw/Address.aspx
However you may want to consider buying a new TV which will have a new ATSC tuner built in. You will still need and antenna.
Hope this helps.
Feb 23, 2010 | Philips 25TR19C 25" TV
''no signal'' is the only thing on the screen
Hi caroldove, I am happy to help. I don't have the model number of your tv so I will have to give generalized instruction.
From the tv menu make sure the tuning band is set to AIR or ANTENNA not Cable,
You will have to have a antenna connected to the tv, preferably an outdoor type, depending on how far you are from the broadcast tower you may be able to use Rabbitears.
From the tv menu do a Auto Channel Search, if any signals are within reach it should find them.
I have provided a link to a site with more information on antennas and direction they should face.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and if you need more assistance. Please rate this solution Lone99star
Jan 23, 2009 | Televison & Video
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
TV does receive broadcast signal
get some rabbit ears..... or a little dish reciever that sits ontop of ur tv til FEB 17th...then u have to have the new converter, which u can get government coupons online ....or ull just get fuzz after that... i use the old cheap rabbit ears antennae and i get 6 channels ....
Oct 25, 2008 | Sansui Televison & Video
TV won't work with rabbit ears
You must change the input on the system to be AIR/Antenna , the way it was before was set to cable/dish/DTV.
The tv sees the input different.
Jun 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sony rabbit ears
The "Horse Shoe Like Ends" on the leads are installed under the Screws marked ANTENNA and then the screws tightened. If No Screws then your Rabbit Ears do not hook directly to this TV. Is there a connector comming out of the back that is Threaded? If YES, then this is your antenna connector (R59) and will require an Adapter for the rabbit ears. Available at Radio Shack.
Feb 04, 2008 | Proton MM2701VT 27" TV
Sansui HDLCDVD220 22 in. LCD TV TV/DVD Combo Logo
293 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
