WASHER TUB SITS LOW AND TO THE SIDE, LOADS OFF BALANCE...
15 YEAR OLD WASHER, WHIRLPOOL LLR6144BQ0 . IT HAS BEEN GREAT UNTIL NOW. I NOTICED LOADS GETTING OFF BALANCE AND UPON A CLOSER LOOK, THE TUB IS ABOUT AN INCH LOWER THAN IT USED TO BE, AND IT SITS SHIFTED TO THE SIDE.
HOW DOES THE HOUSING COME OFF??
ALSO, PLEASE LIST SOME THINGS MY HUBBY SHOULD TROUBLESHOOT TODAY.
THANKS ALOT!
GAVE UP AND BOUGHJT A RECONDITIONED WASHER FOR $100 TWO DAYS LATER. I THINK I DID WELL, THE GUY TOOK THE OLD ONE AS ATRADE PLUS THE $100. THE NEW ONE IS 4 YEARS OLD. THANKS ANYWAY!
Posted on Feb 01, 2009
My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would...
i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Nov 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I have Whirlpool Washer model # WTW5510VQ0, it's 2.5 months old. The machine is balanced properly, and the loads are balanced, and the machine is properly leveled on the floor. When the spin cycle stops,...
Usually, washing machine comes with fixing bolts in the back (for transport only). Check it out if were removed before operating. Usually, there are 3 or 4 of them, with some coloured plastic washers. In the instruction manual also is a note about them.
Sep 11, 2017 | Whirlpool WTW5500X Washer
Magic Chef washing machine getting out of balance
it is a sign that the dampeners on the ends of the tub suspension or support rods have failed
A pack of 4 cost around $80.00 and with a technician doing the job can be done in 15 minutes
with you doing the job , around 1 hour unless you can get the spares people to explain how it is done
get the spares from the service agent spares
any unbalance gets out of control unless it is got under control very early and that is what these dampeners are designed to do and 4-5 years is the design life expectancy
Sep 17, 2017 | Magic Chef CAV2000AWW Top Load Washer
Whirlpool washer does not start after fill with water
It sounds like the washer tub is off balanced. When it is, it will usually not start. Underneath the washer, there are 3 or 4 bolts or nuts, depending on your washer model, that hold the washer to these balance springs. make sure that the bolts or nuts are tight or secure. If this doesn't help, get on a website called Repairclinic.com. They usually will help with home repairs.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Dec 28, 2008 | Whirlpool LSB6300PW Top Load Washer
    Whirlpool Cabrio Leaks Water
    Good luck. Mine did the same and they sent their technicians out to fix the problem. A&E comes out and replaces the tub ring. They told me the washer is now made with the tub ring in place. When he opened the washer up I noticed I now have rust inside my washer. I have spent a month trying to get Whirlpool to replace my washer but they will only replace parts. A&E came out to replace the tub ring and now my door creaks and my washer does not go back together correctly. Hopefully you can justreturn the washer to where you got it. Read other reviews on line. It sounds like this washer is a lemon. Sorry!
    Aug 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Nylon or plastic bushing around tub breaking down
    sounds like you have abadrear bearing, not cost effective to repair by you, parts have a 5-10 yrs warr, you would need to check your manual, usuallt wind up replacing, the rear drum, inner basket, without warr theese parts are probalby 650 dollars. so i would call an authorized servicer(whirlpool wont send you parts even though they're warr)
    Apr 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool calypso
    Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
    Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
    Loud Noise at the End of the Spin Cycle
    some item has fallen down between the outer and inner wash tubs? remove it
    May 20, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    175 people viewed this question
    Top Washing Machines Experts
