Toshiba 57H81 57" Rear Projection Television Logo
bob james Posted on Jul 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convergence problem (Arched picture at bottom )
My set started to show the dreaded arched picture at bottom of the screen. In the convergence menu the green was way off in the bottom left and top right corners. It was a convergence failure. I didn't trust my self to do the repair so I had a tech do it. He put in new convergence IC's (part # STK392-150 or STK392-160)checked out the rest of the boards for trouble spots and resoldered some other spots for good measure and realigned everything. It cost me $375 including parts. I feel it was a good deal for his time and efforts and a great learning experience for me, I paid careful attention and got some really good tips from him, I'll do the next repair on my own with the help of your board! Thanks a bunch!
A
Anonymous
Did he check the resistors as well?? guess not.well,you then can spend another bunch of $$$ on the next repair, DIY-Boy.
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on Jul 25, 2007
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1649963
Points
8439
You got an honest repair price for this job.
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Screen is distorted. Menu bars for program guide are arched.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Picture arches down at the top and arhes up at the bottom
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
DISTORTED PICTURE
*Screen Looks 3-D
*Colors wont align
4helpful
2answers
Color distortion and arched picture
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Arched pink lines across screen. Now green and pink double stacked wording.
*Screen Looks 3-D
*Colors wont align
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Convergence out of addjustment
You need to get a service tech for that problem,it might need new amps for the convergence and then adjustments that only can be done from the service menu.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
