Question about Panasonic KX-P3626 Matrix Printer
How to replace ribbon
I dont know how the ribbon goes into the printer
  • 55 Answers
Hi cci5,
I will guess that you have the old one out, take the new ribbon, it should look just like the old ribbon, turn it upside down and look for a hole that has ribs or like a gear will fit into it, then look in the printer and find the gear, slide the ribbon over the print head thats where ink goes on the paper if the ribbon is printing, then snap the ribbion in place.
Good Luck
Posted on Jan 28, 2009
I have ZP450 printer. There is a squeez noise during printing starting today. What's going on and how to fix it?
Sometimes you will get that noise from buying alternative ribbons or using originals that are too tight. Best way to know is by replacing ribbon for a new one and checking if the noise goes away.
If that doesn't help, please send me an e-mail at
Mar 06, 2015 | Zebra ZP 450 Thermal Label Printer
Adapter power
disconnect the power adapter from the printer, and check if it still goes off after a blink
if it does the same try different wall outlet
if it still does the same thing, try disconnect and reconnect the adapter from the power cable
if still the same issue replaced the adapter
let me know about the situation
Dec 07, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
Just replaced battery but dont know how to reattach ribbon cable on nuvi 200
flip locking flap on connector away from the gold pins. Slide the ribbon cable into the connector on the side with the gold pins as far as it will go. The ribbon goes face down with its gold pins facing down. Then using two fingers flip the locking flap down and toward the ribbon cable. It should click. Be careful, if you snap the flap it is game over.
Jul 31, 2013 | Garmin nuvi 200 Car GPS Receiver
I replaced the ribbon in my Zebra 105Se printer and now neither of the ribbon spindles will turn. Only the roller on the very bottom of the printer is turning and I do not have labels set up to wrap around...
There is a diagram that shows the correct route to thread the ribbon and media in the upper lid. All zebra ribbons come off the supply hub clockwise (left to right) and the ribbon only goes under one roller prior to the print head.
Jul 26, 2011 | Zebra 105Se Thermal Printer
My zebra card p330 dont recognize the colour ribbon, only detect the mono riboon
Try to send the command !SA from the driver. And run the Ribbon calibration
Sep 04, 2010 | Zebra P330i Thermal Card Printer
Canon mp150 printer has error code message and won't work
The ribbon has a letter "L" on the left side. The ribbon connects to a spring on the left, goes thru a slot in the back of the printhead, and connects to a solid hook on the right hand side of the printer.
Jul 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Mar 19, 2009 | Toshiba TEC B-572 Printer
No print with ribbon
Did you put a ribbon in your printer? The zebra does both direct thermal and thermal transfer, but you need a ribbon to get it to print AND have to change the settings to let the printer know that it needs to use the ribbon instead of direct thermal.
Jan 08, 2009 | Zebra Z4M Printer
Evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Jul 04, 2008 | Evolis Pebble 3 ID Card Printer Package...
Clear plastic ribbon came out of printer
Firstly, see if the printer still works. Print something. Then I suggest bringing it into where you purchased the printer. If a twenty month old child pulled it out I am sure it was not burried inside the printer and a Rep at the store can fix it immediately with out cost. Do not let them charge you. Just let them know that this ribbon came out and you do not know where it goes. If the printer works without it, don't worry about it, but keep the ribbon tucked away somewhere and when you go back to the store, when it is convient, have them take a look at it. Let me know how it goes.
Cynthia Charczenko
Jan 15, 2008 | Dell A940 All-In-One InkJet Printer
Panasonic KX-P3626 Matrix Printer Logo
521 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
