Question about Ultra Max Eden Bath Black Ultra Zen Granite Vessel Sink S011
Pop up vessel sink drain
The pop up drain in my vessel sink is stuck in the closed (down) position. How do I fix this?
    New Friend:
Same thing happened to me. Luckily, my SO was more level headed than my "the sky is falling" routine. The bezel or trim ring in the sink unscrews on my model. We were able to unscrew this ring and get at the stopper mechanism to pry it up. After stopping/unstopping several times, it looks like it's working again.
Posted on Apr 19, 2014
    New Friend:
Well, I dont know what B.D. is thinking as my pop up sink does NOT have a lever--but I did check because I have the problem as posted. For some reason the assembly does not pop up now when you press the stopper. ONly thing I could do was remove the trap pieces and jam a wire or thin screwdriver or knife up and pop the stopper up. I am hoping a knowledgeable person posts on how to get this hting operational again--it worked great for two months.
Posted on Jul 17, 2013
  • 979 Answers
Look underneath the sink and you will find the lever that moves the drain up and down. It is probably stuck.
Posted on Jan 30, 2009
  • brian Jul 17, 2013
    Dont know what you are thinking...there are no levers on these assemblites. Take the trap apart and jam a thin screw driver or stiff wire up and pop it up
I have a glass bowl sink in my bathroom. The pop-up drain is stuck in the down position and will not release. How do I fix it??
You'll need to access back side of sink bowl and locate drain mechanism, most likely either the plunger rod has loosened up from clevis rod or clevis rod is positioned to far in towards drain line causing it to bind. Check diagram for assistance in locating parts.
Is the plunger rod tight or loose? You can also loosen clevis screw and see if the plunger rod will slide freely. If it does try moving the horizontal pivot rod up and down, while doing this you should she your drain plunger moving up and down. If it does not then most likely will need to replace plunger mechanism by removing the retaining nut on the back side of the drain line. This will allow you to disassemble the actual drain plunger but I would definitely start with the mechanism of the stopper and clevis where it attaches to horizontal rod.
Sounds like a simple binding. Always be sure there isn't anything stored under your sink which could be causing the problem. Sometimes the most obvious is the last thing we look at.
Good luck.
Aug 16, 2013 | Pegasus Technologies Pegasus Clear Round...
Pop Up Drain in vessel sink
Have a look on u tube see if there is a video on it .
Oct 08, 2017 | Plumbing
I installed the sink drain with overflow and water is leaking from behind the sink and under the countertop. What did I do wrong.
a vessel I dont beleive has a overflow. you need a differant waste for that unless theres something your not telling me
Sep 03, 2011 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Pop up sink basin wont stay down to allow water to stay in basin
I'm assuming this is a mechanical pop up drain. If so then one of three things are happening. Either the pop up mechanism needs to be adjusted, there is build up inside the drain where the stopper is or the mechanical parts are worn and need to be replaced.
Remove the items from underneath your vanity so that you have room to work. Under the vanity the pop up will have an adjustment rod. It is possible that the adjustment has slipped resulting in the drain not closing off properly. Try adjusting the connecting rod and see if that helps. If not move on to the next step.
You will need a small pail to catch any water when you disassemble the pop up. Inside the sink put something under the stopper to hold it in an open position because when you disassemble the pop up it will drop to the closed position and may be difficult to get out of the drain. Under the sink there will be rod coming out of the drain held on with a threaded nut. Unscrew the nut and the rod will come out of the drain and deattach from the pop up inside the drain. From the top of the sink remove the stopper. Clear any of the build up which is usually a distasteful combination of hair and soap scum. A pair of latex gloves come in handy at this point. Check the pop up for wear at the point where the rod attaches. It is possible that this could be worn to the point of not working correctly when the mechanics of the pop up are moved to the closed position. Your local hardware store will have any replacement parts required.
Be sure to reassemble every component before using the sink and test for leaks. Good luck with your project.
Jul 24, 2010 | Home
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Vessel sink drain causes poolin of water.
YOU ALSO HAVE A VENT ISSUE, THE VESSEL SINK DOESN'T HAVE THE LITTLE HOLE IN IT LIKE A VANITY SINK, THERE FOR THE WATER IS GOING DOWN THE DRAIN BUT THE AIR CAN NOT COME OUT, YOU NEED TO INSTALL A STUDOR VENT OR AN INLINE VENT INTO THE DRAIN BETWEEN THE WALL AND THE TRAP CUT IN A TEE AND BRING A PIPE UP TO THE BOTTOM OF THE COUNTER TOP AND INSTALL THE VENT, USALLY HAVE TO PUT A FEMALE ADPT ON THE TOP OF THE PIPE THE VENT COMES WITH THREADS DO NOT GLUE IT IN PLACE, THEY HAVE A RUBBER FLAPPER THAT OPENS WHEN THE WATER IS GOING THRU THE DRAIN AND ALLOWS IT TO PULL IN AIR THEN THE FLAP CLOSES WHEN NO WATER IS RUNNING TO KEEP THE SEWER SMELL OUT
May 28, 2009 | Ultra Max Eden Bath Black Ultra Zen...
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Ultra Max Eden Bath Black Ultra Zen Granite Vessel Sink S011 Logo
1,201 people viewed this question
Top Ultra Max Home Experts
john h
Tom Chichester
Are you an Ultra Max Home Expert? Answer questions, earn points and help others
