Question about JVC AV27F476 27" TV
Input number displayed in corner (V-1, V-2, etc.)
The input number (V-1, V-2, etc.) is displaying in the top-left corner of the TV, and I don't know how to get rid of it. I've gone through the menu about 15 times and found nothing. Unfortunately, I don't have the manual handy and can't locate one online.
  • MrXax Jan 29, 2009
    The solution was to use the "Display" button on the remote (once I had found it). I'm just puzzled as to how that input number began to display without the remote in the first place.
If you dont have the proper remote (like me) i just configured my comcast remote using the appropriate code and pressed to INFO button on the remote between menu and guide. Hope that helps!!
-jc
Posted on Oct 09, 2012
    President:
  • 2,992 Answers
Believe it or not, sometimes things just randomly happen. Remote controls operating using infrared light and coded commands, and sometimes sheer dumb luck results in the TV deciding it's gotten a remote command. This is sometimes more frequent in homes where CFL replacement lamps are in use. The way they work can sometimes cause interference with some remotes, and can confuse the TV as well.
Posted on Feb 06, 2009
How can I get the TV to set to hdmi?
If you have a Hitachi remote HL02121, that means your TV model number is either 32PD7800 or 42PD7800.
According to the Owner's Manual the HDMI connector is activated by going to AV6.
While in the TV mode on the remote, press the '' button with the AV6 above it. That will tell the TV to use the HDMI input.
IF you don't have access to the TV remote, there are INPUT SELECTION buttons on the TV near the Lower Left hand Corner of the cabinet. Press the INPUT SELECTION button until AV6 is displayed on the screen (HDMI Input)
Feb 19, 2016 | Hitachi CLE-960 Remote Control HL02121
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
Sony Bravia 40inch how do I remove input icon
Press " i " (info) button on TV remote and on-screen display will disappear.
Jan 26, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Video Input Label Displayed Constantly
You need Sony TV remote and press Display button and screen display (green label) will disappear.
Regards,
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Video Number Display
This is normal if you dont have a picture on-screen.
if you do have video:
try pressing the "display" button.
Jul 21, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
JVC AV-27D304 display
hit the display button on your remote should turn it off
Apr 08, 2008 | JVC AV-27D201 27" TV
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
No picture or sound
If the screen displays VIDEO 1 then the set is in video 1 mode, looking for a signal on the video 1 input jacks. Press the TV/VIDEO button on the remote (or the set itself if it has it) and cycle around to the input you are actually using.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
JVC AV27F476 27" TV Logo
322 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
