Question about HP Pavilion dv1000 Notebook
Thanks for your support
Until today i found a diagram on internet, i unscrewed all the screws, but im not sure if under the keypad would be any other screw that would hold this corner that does not comes off. If you have any advice, let me know,
Thanks for your help,
Rodrigo
  • HP Master
  • 32,281 Answers
Remove the keyboard screws first, the screws that secure the keyboard have keyboard symbols next to the screws.
Some Compaq/HP have slide catches along the top edge of the keyboard between the number keys and the Function keys. Usually the slide catches are located between the ESC & F1 key, F4 & F5 key, F8 & F9 keys, F12 & delete keys. Slide these catches towards the front edge of the keyboard (ie. towards the space bar) you should be able to lift the keyboard clear. Don't forget to unclip the ribbon cables on the keyboard.
Posted on Jan 30, 2009
Brightness issue
Hi!
Try not to use anything wet next time, just special tissues with soft chemicals only. And keep laptop switched off while you clean it!
Do following:
  1. Get notebook to service, or next steps:
  2. Download service manual from the internet;
  3. Unscrew two keyboard bolts;
  4. Push tiny screw driver in those two holes;
  5. DO NOT DETACH keyboard immediately, just turn it slowly untill you can see wiring;
  6. check if surfaces on and under the keyboard are clear and dry;
  7. find keyboard wiring;
  8. detach it carefully;
  9. dry the laptop;
  10. check connection and put small wires back again...
Have fun if it is working.
If not - change the keyboard.
Feb 04, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
I am trying to remove handles from my 1960's shower handles. they are leaking and i cannot seem to find were you unscrew them at. i took the front screw out and cannot seem to go any further. they...
The screws ae under the center cap. unlike todays faucets this cap is screwed in. You will see a little edge on the cap so you can take your channel locks and turn it counter clock wise. Under that is the bress screws.
You might need a handel puller if they have not been appart for so many years. The puller will also protect you from breaking the stem and the handle.
Hope this helped you out, we all know how little things kick our butts.
Thanks again
Tom
Sep 09, 2011 | American Standard Hampton Two-Handle...
I am changing the oil my self and want to know which screw to unscrew under the car. i need a diagram to release the the oil from the bottom. where do i find one?
2006 uplander, there maybe a cover to remove to get to the oil pan, lets see if i can find a picture of the drain plug.okay im not sure the engine size in this uplander but they all should be about the same, here are some diagrams to help you locate the oil filter and oil pan drain plug. the oil filter is located from under the engine on the driverside behind the ac compressor, the oil drain plug is located on the bottom of the oil pan on the pass/side. heres a diagram of the two . hope this helps.johnjohn2_90.gifjohnjohn2_91.gifjohnjohn2_92.gif
Mar 20, 2011 | 2006 Chevrolet Uplander
C2155 treadmill 1 1/2 yrs old, Nordic track. Panel lights up when the key is attached, beeps a triple beep sound fast about every 15 seconds? Keeps beeping when any of the buttons are pushed and won't...
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Jun 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Open up casing in laptop
Flip it over and draw a diagram of the back make sure to indicate every screw location then unscrew the screws as you do this tape each screw to the location in your diagram. The screws are the most difficult part in disassembling a laptop the diagram ensures you will know where every screw goes. After you unscrew the shell you may need to unscrew screws within your laptop before you begin draw a new diagram and tape the inside screws to your new diagram.
Dec 28, 2009 | Acer Aspire 5315-2153 Notebook
I found out that the ventilation fan of my Dell laptop is not working, so I want remove and check this fan. My problem is how to remove this fan.. Thanks if ever you have an idea..
1st make sure that your warrenty has expired.
The unscrew ever visible screw on the reverse of the laptop.
there is a few hidden one there under stickers... You will see some more screws where your processor is, careful unscrew them, and your done. Was you cleaning your fan or replacing it?
Because your wire may have come loose connecting your CPU fan to the motherboard.
Best wishes.
-Tom.
Jul 11, 2009 | Dell C600 (002UH) Motherboard
How do i replace the optical drive in my acer aspire 3000 laptop?
I have a small tutorial on youtube about memory and hard drive the basic are the same ill post a tutorial in soon ,however to let you know there are a lot of screws and they are tiny things too! by looking at it on the left hand side there are 4 screws that hold it in place then you should be able to just slide it out, im not sure exactly how but ill figure it out and post the tutorial on toutube youll be looking for acer 3000 or zoomietime ill post it later today-z
Dec 19, 2008 | Acer Aspire 3000 Notebook
BIOS Battery
look under the wireless cover.
Oct 26, 2007 | Toshiba Satellite 5005-S504 Notebook
HP Pavilion dv1000 Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
