Question about Nokia 6101 Cellular Phone
Pphone starts up and then 3 seconds later switches off
Nokia 6101 starts up and then switches off.....
battery won`t charge
screen in black and says: contact service
  • 10 Answers
Upgrade software of your phone
Posted on Feb 19, 2009
My Nokia e52 won`t start
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 16, 2012 | Nokia E52 Smartphone
My Nokia 6790 won't turn on, what's wrong with it?
5.Wait 10 seconds.
Step
Thanks
Jun 20, 2017 | Nokia 6790 Surge Cell Phone
How to format nokia 6101
First thing first, not all the Symbian phones can be formatted by the so called "Formatting codes" (Will not work in Series40 phones like Nokia 6300, 7210, 5130 etc and the older Nokia Generic OS based phones like Nokia 1600, 2600 etc). These phones can only be formatted through flashing (Re-installing) their OS software (Firmware) via data cable and computer. Only Symbian S60 (And a few of other series) based mobiles have built-in support for the format codes. So format codes will work in all Symbian^1 (S60 1st, 2nd, 3rd, 5th edition) phones like Nokia 3650, 3660, 6600, 6630, 6680, 6681, 3230, 7610, 6670, 3250, N70, N72, N73, N75, N76, N77, N78, N79, N80, N81, N82, N83, N85, N86, N90, N91, N92, N93, N95, N96, N97, 5800 and other touchscreen phones plus the newer Symbian^3 phones (Nokia N8, C7 and E7 etc). Now lets begin with formatting process: There are two methods to format the phone depending upon the situation: A. When the phone is in working condition:
Just press any of the following two codes at standby screen *#7780# or
*#7370#
Phone will ask for confirmation and security code (Default security code is 12345), enter it and bingo everything in phone memory will be erased and phone will be back to factory settings.
B.
Hard Reset - When the phone is not starting-up (i.e. not working after white screen or Nokia Logo screen)
- then follow these steps: 1. Switch-off the phone
2. Press and hold following three keys simultaneously (Remember "All the three keys" simultaneously):
Green Key (OK or Number Dialing key), Star key (*) and Three key (3 number key)
3. While still holding the above three keys, press the power on/off key to switch-on the phone.
Still continue holding the three keys until the "formatting" screen appears. Now you can release the keys, confirm if asked and then wait for the format to complete. Now the phone will be restored to its original factory settings. Read HERE to know about hard resetting Nokia N97, 5800, 5230, 5530 and other touchscreen S60 5th edition phones.The above format will reset the phone but most probably will not clear the operator's lock codes.
Follow the instructions below to format Nokia 9300/9500 (Communicators)
1. Restart the phone
2. Just when the "NOKIA" logo appears on screen, PRESS AND HOLD following three keys simultaneously:
Shift (Up Arrow key) + Ctrl + F
3. KEEP HOLDING them until phone prompts you whether or not to proceed with format. If however the format menu does not appear this way then remove and re-insert the battery and try again. If the phone display remains black after inserting the battery, press power button on the phone side while keeping the cover open and repeat the above procedure. After formatting, phone will reboot. If the screen remains white after reboot, press power button on the phone side while keeping the cover open.
NOTE: Before formatting the phone, make sure -
1. That you backup all your phone data to either computer or memory card as formatting will erase everything in phone memory.
2. That the phone's battery is charged fully or is plugged in AC power because if unfortunately, the phone runs out of battery during format, then the phone may get permanently damaged and irreparable.
3. If your phone is infected with a virus (Only applies to 1st and 2nd edition phones) then also format the memory card and scan it with a good computer antivirus like Avast.
I hope that the above instructions will help the needy.
Oct 06, 2011 | Nokia 6101 Cellular Phone
My nokia 3110c got switched off. then when i
Nokia 3110c while charging the battery& while taking its got switched off.
Jul 26, 2010 | Nokia 3110 Cellular Phone
Hello how come my rca mp3 player doesnt charge when i plug it in my computer
You most likely have not turned the player off. Connect to your USB port, switch on the player using the slide switch on the side. The screen will light up. To make the battery charge, turn off the player by holding down the 'play' button until you get the bye-bye message. A couple of seconds later the screen will go black and the battery will start charging. Leave overnight if the battery is dead flat.
Mar 17, 2010 | RCA Audio Players & Recorders
Nokia 6300 Switching off
Purchasing a new phone is easy and everyone is always in a hurry to use new phone but never go through the manual properly. You did the same you didn't put the battery on charge for 24 hours. Now to check your phone take another charged battery for nokia put it inside your phone and start it. It will deffinetly work. In order to revive your dead battery keep your battery on charge while the phone is switched off for minimum 24 hours. If it gets revived its ok or else purchase a new one.
Jul 25, 2009 | Nokia 6300 Cellular Phone
Phone dead
Have you tried removing the battery for 5 mins, then re-insert and hold the power button for 10 seconds
Jun 01, 2009 | Nokia 3110 Cellular Phone
Nokia 6101 cell phone
Have your phone reflash its firmware by bringing it to a cellphone service shop. Is this solution/advice helpful to you? You can send me email at st_nardz@yahoo.com for my further assistance. Kindly rate this up! Thank you.
Sep 07, 2008 | Nokia 6101 Cellular Phone
Nokia 6101 Cellular Phone Logo
88 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
