Question about Brother IntelliFAX 1270E Plain Paper Fax
When faxing, the page on the receiving end is completely black when copying the page also comes out completely black
    Genius:
  • 2,120 Answers
You have a bad scanner block, uneconomical replace.
Posted on Jan 29, 2009
Black pages
If everything is coming out Black it sounds like the lamp in the scanner has gone bad. If you can get the part from sharp it might not be hard to replace, but the cost may out weigh the cost of a replacement.
May 14, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Black pages to all work
Nothing you can do. The SCANNER BLOCK is defective.
Jan 31, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Sharp Fax Machine UX-485 recipiant receives black page
If you receive clear copies. Make a test copy. If it come out all black. Yes replace your fax . you have a bad scanner . cheaper to buy a new fax.
May 21, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Black page when copying and sending faxes.
You most likely have a bad SCANNER BLOCK. Not good!
Dec 23, 2008 | Brother IntelliFAX 4100 Laser Fax
Poor Quality
If you can copy ok you have effectively ruled out your machine as you have used both the scanning and printing mechanism of the machine.
It will probably be the fax on the other end as if it sends a poor quality page that's all your machine can receive, a poor line can also cause problems if it is from multiple faxes. If so have your provider check the line (you probably hear static on the line).
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Black pages when making a copy or printing something
Have you tried both drum and toner supplies? cause it sounds like a drum fault, if you have tried a new drum and toner, and it is doing it when printing internal reports, receiving fax's and copying then you have a tecnical issue to do with charge and this would likely render machine unecomical to repair (unless you can find a bad contact with drum on machine). If it receives faxs clearly but copys black then it is different issue (ie optics).
Oct 16, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 1270E Plain Paper Fax Logo
73 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
