Question about Husqvarna Viking 1
Sewing with drapery material
I am trying to make draperies, using average weight woven drapery fabric (not overly heavy or thick). My machine has been working perfectly for everything else, but now won't sew this correctly...the tension is a mess! I think it's because I'm using upholstery weight thread. I've used a different upholstery thread in the past and never had a problem, but that seems to be key when I'm trying to figure this particular problem out. I've changed needles, rethreaded, adjusted the tension, and only an extreme tension readjustment (settings of 9 and 1) got me even close to solving the problem and I'm not thrilled with how that looks. Any ideas?
Switch back to regular thread. Upholstery thread is used for seams that will get lots of stress (as in upholstery; although I use regular thread in upholstery and have no problems). For draperies, regular thread is fine.
Posted on Jul 26, 2007
How do I sew cloth patches onto jacket. I used heavy duty needle but can not find a setting to use. I have my instruction manual but it is of no help for heavy weight material
I don't know about your specific machine, but in general for heavier fabric, increase the pressure on your pressure foot and reduce the length of your stitches.
Feb 10, 2018 | Sewing Machines
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
Every time I try to sew my bobbin is knotting up. What can make this happen?
yes, & the thread may not be the right kind for the fabric, also the tension would have to be adjusted to meet the needs of the thread & fabric
Mar 13, 2012 | New Home HF-3000 Computerized Sewing...
Husqvarna lily bobbin tension issues
Not sure if I can help, but it may have to do with the heavy thread as well as the fabric and needle combination. If the fabric is thick or tightly woven, be sure to use a brand new sharp needle. (If the fabric is tightly woven (like Batik), a thicker thread may present a problem.) In your case, if using a heavier thread, perhaps a top-stitch needle would be beneficial since it has a bigger scarf to protect the thread. With the heavier thread in the top, the top tension will need to loosened. BUT, if you loaded the heavier thread in the bobbin, the bobbin tension will need to be adjusted to accommodate the thread thickness. However, remember that if you adjust the bobbin tension for this project, you will most likely need to readjust it for the next project using different materials.
FWIW, if the machine still works fine with regular fabric and thread, then you'll know that the issues revolve around the current project.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 11, 2017 | Husqvarna Sewing Machines
I keep breaking needles
Are you trying to sew a zig-zag stitch with a straight stitch foot so the needle is striking the foot? Or is it an issue of the material being very thick?
I just googled this machine and it looks pretty lightweight so perhaps you are expecting it to sew fairly heavy materials such as jean seams and it is struggling to do this.
Also keep in mind that you should select a needle appropriate for the sewing job, so 60 or 70 for chiffon and lightweights, 90 for medium weights, 110 for heavy weight and use ball point needles for stretch fabrics.
Hope this helps a bit.
Feb 21, 2011 | Singer 8280 Mechanical Sewing Machine
Does it make a difference whether I use a 14 or 16 in my Kenmore sewing machine, basic 12 stitch. I had a 16 needle in it but after my friend cleaned it, in trying it, the needle hit the presser foot>...
Hi. You use different size needles for different fabrics and fabric weights. Size 16 needles are used for heavy fabric, like canvas, duck, or blue jeans. Size 14 needles are still on the heavy/thick fabric size. Size 10 needles are for very light-weight fabrics and size 12 needles are for medium-weight fabrics. Also, you need to pay attention to the type of fabric--if sewing on knits, you need ballpoint needles. If sewing on woven fabrics, you need sharps or universals. Universals are supposed to be for knits, too....but ballpoint needles are SO much better!
Use the right size and type of needle for your fabric, don't sew over any pins (they can bend or even break the needle), and make sure you don't pull or push the fabric while you're sewing on it. Let the feed dogs do the work of moving the fabric--you just gently guide it.
Hope this helps!
Aug 25, 2010 | Kenmore Sewing Machines
Juki MB-373 Button Attaching Machine
Use a thicker needle.
Release the looper screw and move it back and close to the needle, but without touching.
Tight the looper screw.
Adjust the needle through (left and right) wider.
Jun 07, 2008 | Sewing Machines
Sewing Machines Logo
210 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
