Question about General Electric 27951EE1 - - Phone
Model GE 27951 - Unable to Turn Ringer back on
Yesterday I turned the ringer off using the "mute" key as instruction manual noted. However, now using the same method I cannot get the "ringer off" mode to restore to "ringer on".
The headset volume is turned to zero. Hit the "menu" key on the headset and it should take you to "ringer setting", hit select for the ringer volume and turn the volume up. Not very intuitive but that should get you going!
Posted on Jan 28, 2009
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Do not have english manual and am unable to turn ringer up
You may download a copy of the manual here. The ringer volume instructions are on page 25.
Nov 06, 2012 | Vtech Lands Phones
Dect 6 Manual
my phone still wont ring and i have it full blast!!
Oct 26, 2011 | Uniden Cordless Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How do I turn off the ringer off or lower the ringer setting on my Panasonic cordless phone model #KX-TG5432?
Note, in these instructions: {V} = down on Navigator key (large key in center of phone) {^} = up on Navigator key {>} = right on Navigator key
4 volume levels (high/medium/low/off) are available. The default setting is HIGH. 1 .Press {MENU}. 2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}. 3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}. 4 Press {V} or {^} repeatedly to select the desired volume. To turn the ringer off, press {V} repeatedly until "Off ?" is displayed. 5' Press {Save}. Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
Apr 06, 2011 | Panasonic KX-TG5432 Digital Dual Cordless...
I somehow turned off the ringer and can't figure out how to turn it back on. I can't find my manual at the moment. Is there an easy way to both turn the ringer on and to turn it off?
Most modern phones have 2 buttons for volume control. This typically will change ringer volume (including vibrate / mute).
If that doesn't work, post your model number and we can give more exact answers.
Mar 17, 2011 | Cell Phones
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
How do you turn the ringer on the cd440 model?
The ringer on the Philips CD4402B/37 CAN be turned off by holding down the # key on the dial pad for about 3 seconds (see CD 440 Manual, page 8, Item "I"). And a little "canceled note" icon appears in the screen. To turn the ringer ON when it is off, do the same!
Oct 05, 2009 | Philips CD4401B/37 Phone
General Electric 27951EE1 - - Phone Logo
917 people viewed this question
Top General Lands Phones Experts
Are you a General Lands Phone Expert? Answer questions, earn points and help others
