Question about Bosch 24 in. SHU43 Built-in Dishwasher
Replacing a white Bosch door front with a stainless steel panel
I have a white Bosch dishwasher and I bought a stainless steel panel to replace the white panel. I removed the white panel and two black plastic brackets fell out on the floor. They were on either side of the door near the bottom. I'm not sure how to position them back in the door when I install the new panel. Can you HELP???
    Brigadier General:
  • 3,614 Answers
may i know the specific model of the bosch dishwasher that you have.
Thank you
Posted on Jan 28, 2009
  • micromaster
    micromaster Jan 28, 2009
    also identify on which exact location, and part name on the unit you need help
Is there a stainless steel door panel replacement for bosch dishwasher shx43c02uc
If there isn't, you might try having a local metal shop cut you a piece of stainless, fold and weld the edges to make a cover for the door and adhere it either with epoxy or a small tack-weld. I wound up having to have a cover made for my Mom's stainless-steel fridge when only white and black ones were available and a metal shop doesn't charge much for it.
Alternately, if the metal panel is housed in a frame, try taking apart the frame, removing the panel and flipping it over. They usually just paint the one side, and if the other side is bare metal, such as aluminum, you can use sandpaper to give it a brushed finish and some clear-coat spray paint to give it that shiny stainless look and durability. Then just reassemble the door with the stainless-looking side facing outwards and the wrong-color side facing in. Worked for Mom's dishwasher!
Aug 31, 2012 | Bosch Dishwasher Door Panel White - 245067
Replace Bosch SHU3306UC door panel with stainless steel?
Instead of replacing the entire door.
Go to http://www.applianceart.com
These guys offer every solution imaginable for refacing your existing dishwashers. They make dishwasher covers in a variety of designs, textures, solid colors and stainless. Check out their website and if you still have questions get in touch with these guys. They are able to walk you through all the available options and keep you from having to replace the entire door.
Jan 20, 2012 | Bosch SHU3306UC Built-in Dishwasher
Can I exchange the white door panel for a stainless steel panel on Bosch Dishwasher SHU5312UC/U11?
from my research all but 3 models have that option, I didn't see yours there, But if you contact sears or www.homeeverything.com I'm sure they can assist you
May 18, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Can the front panel on the Bosch dishwasher be ch...
You can not get the finish! It will be an expensive affair!
May 21, 2010 | Dishwashers
I want to replace the white door panel with stainless steel
Have you checked with www.applianceart.com? They have faux stainless and real stainless options. PLus a ton of other choices there.
Feb 21, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
Can I get a different front door for my dishwasher?
From what I could gather, it appears that there may be a door panel kit available for your dishwasher. The kit appears to have the panel kit and the curved handle included. Some links for visual reference:
SGZ1005UC Stainless w/tubular Towel Bar Handle
SGZ1006UC Stanless w/curved Handle
Feb 06, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Door clips fell out
IF THE CLIPS ARE BLACK AND ABOUT 1 1/2 INCHES BY 2 1/2 INCHES THEY GO ONTO THE HINGES AND THE DOOR GOES OVER THE TOP OF THEM, YOU MAY NEED TO LIGHTLY FLEX THE SIDES OF THE PANEL TO GO OVER THE HINGES. THE TOP OF THE PANEL SHOULD SLIDE UP INTO THE CONSOLE BEFORE THE BOTTOM WILL GO IN. HOPE THIS HELPS YOU OUT
Feb 07, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
369 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
