Question about Toshiba TP43H60 43" Television
I have a TP43H60 toshiba and the power light continues to blink red and there is no picture or sound. I can't turn it off either unless I unplug it??
    Habit-Forming:
  • 28 Answers
You have blown one of the pecos fuses, probably the f850 or f852, you can test them with the power unpluggrd and with an ohm meter. Replace them with only the recommended amps fuse. Your set is going into standby, because of the blown fuse.
Posted on Jan 28, 2009
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
Toshiba big screen tv. tp43h60
Good Day;
I would suspect the convergence IC's, to confirm this unplug the convergence yoke, all three. If TV comes on IC's are bad. Also, check the little green pico fuses. Good Luck, big IRISH.
Nov 10, 2008 | Toshiba TP43H60 43" Television
Jcv rear projection tv modal# hd-61fn97
no picture and no sound blue and red light flashing continually cannot turn off unless we unplug it.
Oct 13, 2008 | JVC HD-61FH96 61" Rear Projection HDTV
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Sep 16, 2007 | Toshiba TP43H60 43" Television
Toshiba TP43H60
I have the same issue with my toshiba 32" circa 2000. I am told that it is a burned out diode of some sort and it is a horrendous repair job.
Aug 27, 2007 | Toshiba TP43H60 43" Television
Toshiba tp43h60
You have a bad regulator IC or something in the seweep power supply is blow out. if you can read a schematic, i suggest you get one to troubleshoot the solid state circuits in this TV set. if you do not have any solid state repair experience or no electronic background, play it safe and call in a pro to assist you in the repair of this TV set. Good Luck.
Mar 17, 2007 | Toshiba TP43H60 43" Television
Toshiba TP43H60 43" Television Logo
338 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
