Question about DCS 48 in. CS-484GG Gas Cooktop
If the temp is set between high & low, all burners "click"
If I try to set the temp between high and low, the burner clicks.  The clicking is coming from all the burners despite the fact that only one burner is being used.  When I look at the other burners, it looks like they are trying to ignite.
I have a 48" DCS cooktop with 4 burners, a grill and a griddle.  It is about 9 years old
  • christina nichols Jan 28, 2009
    I am not concerned about safety as it has been doing this for years - I am just now fed up and trying to figure out why, on such an expensive piece of equipment, I cannot cook on Medium.
  • 19,396 Answers
The clicking sound are the ignitors that keep coming on, that means that there is a short on the wiring harness to the ignitors.
Replace the wiring.
Enter model number here to find replacement parts and diagrams.
Posted on Jan 29, 2009
    President:
  • 1,214 Answers
Remove all the burner caps and wash in warm soapy water, scrubbing with a plastic scrubber.
Do the same for each of the burner bases, including the knub where the arc ignitor rests.
Replace the burner caps, making sure they are properly aligned in the burner bases.
Over time, these items will accumulate a non visible coating, a residual of cleaners and food spills. Cleaning will allow the ignitor sensor system to determine that a flame is present.
Posted on Jan 28, 2009
  • 130 Answers
Does it lite at all? Most gas ranges will turn on all the ignitors when you try to lite the top. I would say you have moisture on the ignitors. try cleaning them a bit with dry cloth.
    Sergeant:
    Champion:
  • 239 Answers
It is normal for all burners to spark , but the only one that will lit is the one that you open, then turn knob until the spark stops!
    President:
  • 2,559 Answers
That is normal,it is due to the use of 1 power coil for the whole system,rather than having 1 for each burner.(The coil sends power to all ignitors at the same time,but only the burner calling for gas will ignite)
Please rate this fixya
    President:
  • 2,110 Answers
Yes is safe you probably got the ignighters switch's wet if one is wet will cause all to fire after awhile they dry and return to normal
Why do Jenn-Air cooktop igniters click when the exhaust fan is on med-high and the burners are on low flame setting ? ?
Igniters sense flame temperature, and if the fan cools the temp sensor down, your cooktop thinks the flame has gone out, so it clicks to reignite it.
Sep 02, 2014 | Jenn-Air Cooktops
When any of the 4 cooktop burners is turn on to a low setting all the burners "click". Turning up the burner to high stops the problem.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jul 08, 2010 | Dacor Preference SGM365SS Gas Cooktop
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sep 04, 2008 | DCS 48 in. CP486GDSS / CP486GDSSL /...
Hello- Will In Houston Teas
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 25, 2008 | Jenn-Air JED8230 Electric Cooktop
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Ignitor on burner #2 keeps clicking even after burner #1 lights
Jenn Air uses a reignition system on their gas cooktops.It is very important that you have a well grounded recepticle. Please check that and please get back to me.
Sep 11, 2007 | Jenn-Air JGC8536 Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Nov 26, 2006 | Jenn-Air JGC8536 Gas Cooktop
DCS 48 in. CS-484GG Gas Cooktop Logo
76 people viewed this question
Top DCS Cooktops Experts
Timllfixit
Dennis
Lawrence Oravetz
Are you a DCS Cooktop Expert? Answer questions, earn points and help others
