Back to:
Tags:
GE 25GT516 TV
GE 25GT516TX1
posted by MaryO on Jul 24, 2007
There are 6 white dashes on the lower righthand side of the screen which appeared yesterday, July 24. Here is what they look like --:-- --
They are driving us crazy! No help was found in User's Guide and no help from GE tech.
Can you help get them off?
Thanks!!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 26, 2007
Thanks for Trying (70)
MikeNJ1964
Rank:Guru Guru
Rating: 89%, 608 votes
The GE (actually RCA) 25GT516 uses the CTC185 series chassis. The dashes you show look like the old display of a clock that has not been set. I have never heard of this chassis producing those dashes continually on the screen, so the first thing I would do is eliminate any cable box, satellite receiver, DVD or VCR. If you have cable, run it directly to the set and see is the dashes are there. If you are sure that the dashes are being generated within the TV and you have properly set the clock and turned off the OSD, then it soulds like an EPROM problem and the set should be serviced by a qualified tech familiar with the CTC185 chassis.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on GE 25GT516TX1:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
GE 25GT516 TV
how can i acces to the menu without the remote control
GE 25GT516 TV
i press the menu button in front of the tv, but nothing...
GE 25GT516 TV
my tv just shows channel 99, it doesnt change channels,...
GE 25GT516 TV
my son press many buttons from the menu button and now it...
GE 25GT516 TV
I hooked up everything, but
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
