Question about HP LaserJet 1300 Printer
HP Laserjet 1300 printer Yellow light flashing
HP Laserjet 1300
I was printing a run of 60+ pages at around page 35 pages started coming out black (not solid but all over) with the yellow light flashing.
I've checked for jams (none) all doors closed and toner OK. After switching off and restarting light still flashing.
On your advice I have changed the toner cartridge - yellow light still flashing!!
Any other advice?
    New Friend:
  • 3 Answers
Dear friend,
when the printer give you a yellow flash that should be means a fault happen so you have to do the following:
1- check if any messages appears on your computer when you trying to print something that should be help you. if not go to step 2
2- black paper may be come from the (P.C.R.) that is the charger of the drum, so if you can open your cartridge and check the charger at the op of the drum that will be good and if not you may change the cartridge and check again.
3- Also, you can release the cartridge and look inside the printer may be you can find something wrong or something need to fix
4- Other wise go to hp help center
Posted on Jan 20, 2014
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
4 Suggested Answers
  • 81 Answers
SOURCE: HP Laserjet 1300 yellow light flashing
Change the toner cartridge and see if the problem is rectified. Sounds like a part failure in the cartridge. This can happen at anytime, but more so when the cartridge is at the end of its useful life
Posted on Jan 24, 2009
yooperbud
  • 8637 Answers
SOURCE: HP LASERJEY 1300 YELLOW LIGHT FLASHING
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Posted on Jan 29, 2009
SOURCE: HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Posted on Mar 17, 2009
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
Everytime i print, my lj printer prints a whole page with black ink.
Does the black page come out first, and then your original print comes out fine ? If yes, you might try to update/replace your driver. Print from several applications and see if there some differense. It might be a software-error.
Or does the black page come instead of your original print ? If yes, try to replace your toner-cartridge. If the problem remains, there's some error in your High Voltage Power Supply and you might as well buy a new machine.
Jul 05, 2009 | HP LaserJet 1300 Printer
Jan 29, 2009 | HP LaserJet 1300 Printer
Jan 23, 2009 | HP LaserJet 1300 Printer
I am getting verticle black streaks when I print, please help.
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Nov 21, 2008 | HP LaserJet 1300 Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
HP Laserjet printer not printing
Try clearing the que. It may be the first job is to big for the memory. Also, be sure the printer is not in manual feed mode. The directions will be in the user manual if you are not sure how to change it.
Jan 19, 2008 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
711 people viewed this question
Ben Johnson
