Question about HP LaserJet 4000 Printer
Savin 2522 Copies with a series of unwanted lines
We are a small church that received a used Savin 2522. About 6 months ago lines started to appear on the copies we made and it has only gotten worse. Someone in the church suggested changing the drum. Any help would be wonderful! Thanks
    Genius:
  • 2,120 Answers
Replace the drum.
Posted on Jan 29, 2009
Savin C2824 Toner roller marks on blank side of color copies
dust from cartridge builds up inside machine. you can clean it up with a small paint brush and some canned air .
Jun 27, 2012 | Savin Office Equipment & Supplies
How do you get rid of lines that are coming through on copies Savin 2518
U PROBABLY NEED A NE DRUM. OR HAVE DFIRT ON LENSES AND MIRRORS
Sep 13, 2010 | Savin Office Equipment & Supplies
I have a savin 2522 and it has a few lines running down my copies
few fine lines is due dirty optics mirrors and lamp, and it may also came from dirty charge rollers due to dirty/worn out charge roller cleaner, worn out cleaning blade and seal blade. to check this, clean/wipe off toner or dirt from charge roller with cloth wet from alcohol or water. then run some test copy.
Mar 03, 2010 | Savin Office Equipment & Supplies
Savin 9940DP ''Set Key Counter''
Key counters are used when a copy machine is set up for public use where copies are charged on a per copy basis. Key counters look like small boxes that plug into the side of the machine and they have a counter on them that looks like a cars odometer. A user plugs in the key counter, makes copies and then takes the counter to a register to pay for the copies they made. Sounds like that is what you have going on.
Nov 02, 2009 | Savin Office Equipment & Supplies
The display says following output tray is full.
Look at the area where the paper just exits from the machine. You should see a small black plastic arm. Make sure it has not become stuck in the up position or knocked out of place. This arm is what tells the machine that the area is full of paper. Also your machine is the same as Ricoh 1022, Savin 2522 in case you need to do more research.
Oct 19, 2009 | Gestetner 2212 Digital Imaging System...
Scanner cannot find computer
Did you upgrade to Vista by any chance. It's not recommended to use scan router with vista.
Jun 10, 2009 | Savin Office Equipment & Supplies
Savin 2522 sc542 error code
It's a fusing warm up error. The temperature isn't reaching the right rate within 20 seconds.
There isn't a reset procedure due to safety reasons. If you replace the thermistor, it should go away.
Mar 16, 2009 | Office Equipment & Supplies
Cartier Tank Basculante Reverso Watch
Yes, it has a small second hand and dial at the 3:00 position, and the date is at the 6:00 position.
Apr 23, 2008 | Watches
HP LaserJet 4000 Printer Logo
173 people viewed this question
Seeker5211
Seeker5211
