Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Agitator not engaging
Model # LSV7244AQO agitator turns freely by hand when machine is off but does not engage when the washer is running. can you give me a part munber and directions on how to solve the problem. thank you very much andy.
  • 130 Answers
It will spin freely try to move it back and forth in full spins. if it spins both ways you need to replace the agitator dogs
Posted on Jan 28, 2009
Kenmore 19233 sewing machine. Then handwheel is broken, spins freely. Machine works perfectly otherwise. How do I remove the handwheel and replace it.
If the drive belt is not off or broken, then check hand-wheel setting. On some models the hand wheel can be pushed in (to engage) and pulled out (to disengage) for using bobbin winder. If it is disengaged the hand-wheel will spin freely. On older models there is a smaller wheel that has to be hand tightened in order to engage rest of machine. Hope this helps.
Nov 20, 2016 | Kenmore Sewing Machines
My KitchenAid washer will agitate, but the upper agitator assembly is not turning and I hear what sounds like marbles moving/slipping. Can I take that top piece off to look at it?
Based on your description, the problem is likely the self-rising tube that comes from the base (bottom) water feed tube. It may not be rising to engage the top assembly....
If it fails to rise all the way, the water will just spray into and on it and cause it to wobble versus rotate.
Pull up on the bottom feed tube - just to confirm that it will move freely...... (food, soap scum and age can prevent it from moving freely.) Clean and retry the washer.....
Nov 07, 2009 | KitchenAid KAWS700L Top Load Washer
Brand new agitator does not rotate. I realized that I did not buy a new "seal-cap" that goes between the agitator and the cap. Would the missing cap cause the agitator to fail to rotate? GE spacesaver...
by 'rotate' do you mean that it will not turn at all or that it turns in both directions and does not 'rachet', turning in one direction only and agitating the clothes? If it rotates freely in both directions, it's probably your agitator dogs not engaging either due to improper assembly or breakage.
Aug 21, 2009 | GE Washing Machines
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
I have a 12 year old whirlpool washing machine model lxr7144eq0
To determine if the transmission caused the belt to wear, then unplug the washer, and looking up inside toward the transmission, note the large diameter pulley that the belt goes around. See if you can turn it by hand. It should turn freely in both directions.
This isn't a 100% guarantee that the transmission is good, but will give you an indication. Make sure the washer is at the end of it's cycle when trying this.
If it turns, replace the belt and see what happens. If it doesn't, make sure none of the solenoids are engaging the linkage, otherwise, you'll be trying to turn the drum or agitator.
Feb 04, 2009 | Whirlpool Washing Machines
Agitator top is not engaged to the bottom part
This problem is generally caused by worn agitator dogs which are part of the agitator cam under the top portion. The dogs act as a clutch to drive the upper portion of the agitator. The do wear out with age and require periodic replacement. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is a very simple problem that can easily be repaired by the average do-it-yourselfer for very little money. Replacement parts can be purchased on line at searpspartsdirect.com. Just type in your model number and look under the "Agitator, Basket and Tub Parts" heading for item number 10. For a little more, the entire cam replacement kit (which includes the dogs) can be purchased as item number 9. If you do not wish to purchase on line, take the part numbers listed on the website and go to your nearest appliance parts retailer. These parts are commonly part of their in store inventory.
Read through the link thoroughly and let me know if you have any questions. I hope this helps you.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not engage in spin cycle
could be a stuck gear box. this gear box could have a mechanical problem on the spin cycle.
it usually turns the reverse rotation if it wants to spin.
check the pulley of the gear box, rotate it in one direction for twenty revolutions. see if it agitates. then next turn it on the other direction and observe if it is binding or stuck.
if you can remove the gear box and check the mechanical gears inside, maybe you can find the problem and replace the part.
tnx 4 using fixya,
drcool
Oct 16, 2008 | Frigidaire CWS3600AS Top Load Washer
Won't agitate!
does your model have a drive coupling its between the motor and gearcase,when they brake the machine wont wash or spin and makes a wierd noise
Jan 12, 2008 | Whirlpool LSR6232J Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
201 people viewed this question
Dan Webster
Dan Webster
Sal De
