Question about Brother IntelliFAX 1270E Plain Paper Fax
"check paper" error appearing
We cannot find any obvious cause for this.
Able to send a fax, but not to receive.
    Champion:
  • 320 Answers
ON THIS MACHINE THERE IS PAPER FEED ROLLER THAT NEEDS TO BE REPLACED THE TOP HALF OF THE FEEDER MUCT COME OFFF TO DO THIS OR YOU MAY HAVE A SENSOR OUT OF WACK WHICH IS UNDER THE FEEDER. IF YOU ARE GOOD WITH HANDS YOU WILL FIND IT GOOD LUCK
Posted on Feb 03, 2009
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
May 24, 2017 | Epson Office Equipment & Supplies
I have an HP 8500A printer/scanner/fax. Everything works but the fax. I can receive but I can't fax out. I get error 348, 321 & 358.
Hello and Welcome to FixYa!
Sir/Ma'am these error are basically due the Communication error of Receiving/Remote Machines. But each error shows different meaning.If during fax you receive the Error 348 then it may be because of several reasons like:-
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise,Other reasons can include power outages and other power-related problems.
  2. When The call-waiting service can cause this error or the remote user pressed the Stop key while the reception was in progress.
You can solve the Error 348 by the following
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
If during fax you receive the Error 321 then it is because of:-
  1. There was a communication error with the receiving fax machine due to poor telephone line conditions.
You can solve the Error 321 by the following:-
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
If during fax you receive the Error 358 then it is because of:-
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
You can solve the Error 358 by the following:-
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 05, 2011 | HP Photosmart 2710 All-In-One InkJet...
Can not send fax. The receving fax rings but my machine does not respond and send the fax. I can receive ok.
The document does not feed into the machine.
Be sure the document is not wrinkled, and you are putting it in correctly. Check that the document is the right size and not too thick or too thin. (See document types and sizes on page 43).
You cannot receive faxes automatically. Check if "TEL" appears on the right side of the display. In TEL mode, you
cannot receive a fax automatically. Be sure the handset is seated on the cradle properly.
The machine cannot receive faxes manually. Do not hang up the handset before pressing Start/Enter to receive a
fax.
The machine does not send anything. Check that the document is loaded face down. Send should show up
in the display after it dials. Check if the machine to which you are sending can receive your fax.
Dec 22, 2010 | HP 1010 Plain Paper Thermal Fax
When trying to send a fax from a Canon L16-L140 the error message: "Document ready, checking scan error, please press OK" appears. When pressing OK nothing happens. I can receive faxes fine though Please...
Hey! If the take out the cover that's covering the receiving paper,Look in there and u will see a black lever with a green sticker on it!Make sure its clipped into place by pushing it upwards un till you hear the click sound!Then press ok!!Enjoy! Good Luck!
Sep 27, 2010 | Canon L120 Fax Laser Printer
Fax will send but not receive faxes. Says printer
Mite need to clearthe memory of the fax machine
Mar 21, 2010 | Sharp Office Equipment & Supplies
Fax reception fails
Hello Dear,
The error message 242 appears in HP Photomart C7180, when the remote machine (the fax machine at Fax Sender side), is having problem, and it is trying to receive fax instead of sending. So actually both these machines try to receive the fax at the same time.
On many fax machines it is possible to accediently initiate the fax reception when:
1. The paper is not loaded in the machine
2. Or The paper is not correctly loaded.
You may contact the fax sender to check the above things. There is absolutely no problem with machine at your end.
Thanks
Mar 10, 2010 | HP Photosmart C7180 All-In-One InkJet...
Brother Fax-1030 plain paper sending constant 'check paper' error
I got this error when I put the paper in without pulling forward the flap that hold the paper. It seems that the action of returning the flap to it's closed position sets the paper in the correct way.
I'd give that a try.
Mar 16, 2009 | Brother FAX-1030e Plain Paper Thermal...
Will not fax or copy - Given error light
The thermal roll is basically a roll of 'carbon' like paper that is used to transfer the image to your paper (terrible technolgy, and a massive waste of money for the end user....but that's another story)...it likely needs replacing -it's only good for 300-400 pages.
Feb 24, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
Problems sending faxes with B820
make sure it says doc ready before pressing start!
Feb 28, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Brother IntelliFAX 1270E Plain Paper Fax Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
