Question about iLO DVDRH04 DVD Recorder
Having problem opening the tray
The tray is stuck when I press "open/close" the display shows OPEN, makes no sound and than the display shows NO DISC, but the tray does not open at all.
    Problem Solver:
  • 5 Answers
I have this same problem with my unit. Most of the time it works with the remote, but it doesn't with the buttons on the front of the unit. Most of the time I run my finger nail (don't laugh) around the tray door and it free's itself. I'm not sure what's sticking in there to cause the problem, but...the old fingernail does the trick. You may want to check and see if there is anything on the tracks and I'm thinking about a little wd-40 sprayed on a cloth and then rubbed genlty on the sides of the tray...be careful not to spray the unit itself or expose anything on the inside...it can't hurt to try, but then again, you might want to make sure it won't mess anything else up. Hope this helps.
Posted on Jun 05, 2009
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
My dvd is not working on my blue ray it saying go to update some software
you will need to download the update from
http://pages.samsung.com/us/bluraysupport/support.html
how to - make an update CD
  1. Download the software update file for your hardware.
  2. If the update is compressed (zip file or rar file), the file should be uncompressed before burning.
  3. You must burn the update file on a blank CD-R/W disc by using "Burn Image" option.
  4. Burn an image file of the software update file (*.iso)
how to - update your player with your CD
  1. Press OPEN/CLOSE to open the disc tray.
  2. Insert the update CD-R disc with the software update, label facing up.
  3. Press OPEN/CLOSE to close the disc tray.
  4. Wait 1-2 minutes until the screen displays "Verifying Firmware version..."
  5. After checking old and new version, select "Yes" or "No" with "?" or "?"
    on the remote control. If you select "No", BD-P1200 will be powered off in a state of tray open.
  6. Press ENTER button on the remote control.
  7. Remove the update CD from the tray.
  8. Screen will display "Firmware Update Now Processing... Please do not turn off the power".
    This process will take 4-5 minutes. When done the screen and power will turn off automatically.
  9. Turn the unit on again with the power button. They tray will close automatically and a
    Menu Language Selection screen will open.
  10. Select the Language you want by pressing the corresponding number button.
  11. Update is complete.
Jan 15, 2011 | Samsung BD-P1500 Blu-Ray Player
I have a DVD Recorder, Lite-On LVW-5005X. I have been having sporadic problems with the disc tray not opening for some time. But usually after repeated attempts, it would open. I have recorded and...
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Dec 10, 2010 | Lite On LVW-5005X DVD Recorder
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
The open/close tray will not open. It reads open then close but does not open. It makes a groaning sound as if it's trying to open but can't. There was no warning of this. The display shows imput L2...
Assuming there is nothing stuck in the tray, the gears over time will wear out and the tray will no longer come out. Another possible cause is a weak motor, either way the tray will have to be replaced in order for it to work properly again.
Oct 27, 2009 | Panasonic DMR-E55 DVD Recorder
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
DVD-RAM will not eject via "OPEN" tray command
Hey I just found out how to UNLOCK the tray
Power up the unit, wait for it to read the disc if one is inserted.
hold the stop button and the power button down together for 5 seconds
the display will show UNLOCKED
Open/close button should be restored
Apr 03, 2008 | Panasonic DMR-T2020 DVD Recorder
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
iLO DVDRH04 DVD Recorder Logo
190 people viewed this question
Top iLO Televison & Video Experts
AFcityboy
Level 1 Expert
Radames Pagan
Radames Pagan
loony2ns
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
