Question about Plantronics CS60 Professional Headset
My headset was working fine (Plantronics CS50). Now I can use it to talk on my phone to office extensions but when I punch an outside line, their is a loud, very loud noice that prevents one from hearing anything. What can that be??
  • Wajid M
    Wajid M May 11, 2010
    Dear ajia Did the first solution work for you? I mean did resetting the headset got rid of the very loud noise that was preventing you from hearing anything on the outside line. Thanks!
  • 32 Answers
The CS50 is not a phone and it is not specific to VoIP.  It does not transmit over the ehternet wiring in your office space.
Here is how to really "reboot" or as the manufacturer refers to it "perform a system reset" on your headset:
1. Lift the headset off of the charging base.  Make sure the headset is turned off.  The green light should not be lit on the charging base. 2. The mute button is on the black little wheel on the top of the headset.  If you push it straight down with the tip of your finger it will mute it.  Now, at the same time, push and hold the mute button with the call answer button.  You will see a green light on the headset flash quickly.  After 2 series of flashes, let go of both the call answer and the mute button. 3. Place the headset back on the charging cradle.  Leave it there for 30 seconds.  Lift it up and try it now.
Also make sure that the red light on the base is lit up.  This means there is power to the system.  If it's not, check the connection.
Posted on May 22, 2009
    Scholar:
  • 140 Answers
Your plantronics is a voice of IP phone and does not work like a conventional telephone. It transmits over the ethernet wiring in your office space.
I would first and foremost try to reboot your phone. (Unplug the cables from the back and wait a few seconds the, plug everything back in.) Your phone should take around a minute or two to boot up and get back on the system.
If that doesn't help, you will need to call the telcom company that services your PBX. The programing and testing is not "user serviceable". It requires special software and passwords to log into the system and check the programing status of your phone.
Posted on Jan 28, 2009
Cs540 caller hears echo
Hello, if they are hearing echo, you are speaking too loud. Or have the receiver too close and talking too loud. Or the person on the other end of the line has phone line problems.
May 16, 2014 | Plantronics CS50 Wireless Headset
Were does the battery go?
The battery is in the top part of the microphone. If you look at the underside of the microphone that lays against the side of your face you will see the battery door cover. I will put a link below that shows an easy way to remove the cover so you can replace the battery when needed. I will also include the link for the batter.
Plantronics CS55 Battery Replacement
Plantronics CS50/CS55 Battery
Good luck from Headsets Direct!
Oct 25, 2011 | Plantronics CS50 Wireless Office Headset...
Problem for Plantronics CS50 Wireless Headset - I can hear the person on the other end when the configuration dial is set to 1,2 or 3. But th other person cannot hear me. When I set the dial to 4, others...
The following is a cut from Plantronics web site. I hope it helps, It's just possible you have missed a setting, such as the mute switch.
The CS50 has both transmit (how you are heard) and Receive (how you hear) controls on the unit itself.
The Master Transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
The Master Receive setting is on the back of the base (below the picture of the microphone) there is a 1234 switch 1 being the highest setting and 4 being the lowest setting. You can fine tune this setting by using the volume control on the headset itself. This is the rocker volume wheel on the back of the headset (opposite of the microphone).
The headset volume control also doubles as a mute switch if you press it in, instead of rocking it back and forth.
There are also configuration settings on the left hand side of the base. This is a dark grey dial with a 1234 on it. There are notches to the right of this dial. Whatever number is lined up with the notches it what setting you are on.
This needs to be set to the clearest setting.
There is a silver button on the headset itself which is your “Talk button”. This is what you press to use the headset and or transfer the call from the headset back to the hand receiver.
There is also a switch on the right hand side of the base which is your the IntelliStand feature.
When the CS50 is used in conjunction with the HL10 handset lifer you can enable the IntelliStand feature.
The IntelliStand feature senses when the headset has been removed or placed into the CS50 base unit which automatically activates the Handset Lifter and enabling headset/handset mode to answer or end the call.
There is a switch towards the bottom on the right side of the base unit that will switch the IntelliStand feature On and Off.
Apr 11, 2010 | Plantronics PL-CS50 Professional Headset
Handsfree not working
Make sure that the phone cord that comes out of the back of the CS50 base plugs into the Handset port of the avaya telephone, not the headset port.  Then make sure the coily cord that comes out of the telephone handset is plugged into the front of the CS50 base.
It takes 1.5 hours to charge to 80% capacity, and 3 hours for a full charge.  You will know it's charged fully because the yellow blinking light on the front of the base will now be solid.
May 15, 2009 | Plantronics CS-50 Professional Headset
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
No Program folder for Plantronics application / driver.
The CS50-USB from Plantronics extends wireless freedom to your softphone. It’s the first wireless headset for VoIP applications with remote call detection and answer/end capability via PerSonoCall software (built-in).
Enjoy yourself without bothering about software!
Jan 05, 2009 | Plantronics CS50-USB Professional Headset
Static
SYSTEM RESET To recover from some fault conditions (refer to the Troubleshooting Section) you may need to perform a system reset. To perform the system reset follow this procedure: 1. Press both the talk button (14) and the mute control (15) button on the headset for 5 seconds. 2. When the talk indicator light (17) on the headset blinks, release both buttons. 3. Press the talk button again. 4. Next reset the base unit by disconnecting the AC power adapter (24) from the AC power adapter jack (7) for 5 seconds, then reconnect. The system reset operation is complete.
Jun 19, 2008 | Plantronics CS50 Wireless Office Headset...
Plantronics CS60 Professional Headset Logo
305 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
