Question about Gateway GM5084 PC Desktop
PC not booting when AVERmedia TV tuner card is inserted
Hi experts,
My tv tuner card was absolutely working fine. Suddenly, it started giving trouble. whenever i insert that card in PCI slot, my PC will not boot up. The monitor LED will be blinking (same as when PC shutdown) but the CPU power LED will be ON. Even the hard drive LED will be continuously glowing.
Some days back my SMPS was gone due to some power fluctuations.. I am wondering if that can affect this card, I guess it wont.
please help...
-- Anand
  • adkolte2003 Feb 25, 2009
    Hi Techguru... thanks a lot for your reply..
    I tried removing the battery and resetting the BIOS to default.. but still the PC doesnt boot when I connect the TV tuner card.
    Even the setup screen wont come if I connect the TV tuner card.
    I guess.. i'll have to buy a new card now :(
  • 51 Answers
Techguru2009: Seems you might have a conflict with your I/O. You need to reset the bios either by loading defaults or just remove the CMOS battery for ten minutes. After start the computer without the pci card. If all is well, then shutdown. insert the card in a different slot on the motherboard. Power up and the bios should recognize the update. Hope this helps.
Posted on Feb 24, 2009
Hello,everyone!! i have lenovo ideapad y560 with inbuild tv tuner & also a connector wire to connect dish cable to laptop... but my question is that how do i watch tv on my laptop OR in which...
Hi
TV tuner cards allow you to view programming on a computer system. Although desktop computers allow you to install internal TV tuner cards, laptop systems do not have the available space for internal cards. Because of this, laptop computers have PCI express card slots. This slot allows you to install and remove (at your will) additional hardware, such as TV tuner cards.
  • TV tuner card
  • Driver installation CD
  • Software installation
  1. Locate the PCI express card slot (located on the side of your computer opposite the disc drive). Push in on the protective cover on the slot to unlock it from the case. It pops out slightly, allowing you to remove the card.
  2. Slide in the TV tuner into the PCI express card slot. The card clicks into place and a light blinks on when the card has connected successfully to the laptop computer.
  3. Insert the driver installation CD into the disc drive of the computer. Momentarily a driver installation wizard appears on the screen. Click "Next" on the welcome page, then accept the given license agreement. Choose "Next" two more times, then select "Install" and the drivers from the driver installation CD install onto the computer.
  4. Eject the driver installation CD and insert the software installation CD. This is the program you use to view the connected receiver. As with the driver installation CD, wait for the installation wizard to load up onto the screen. Accept the license agreement, leave the installation name and location blank, then click "Install" to install the software.
  5. Restart the computer. Upon restart the laptop is ready to begin using the TV tuner card.
Jun 12, 2011 | Lenovo IdeaPad Y560 Laptop
No picture display at all but with sound
This most likely a codec issue, TV is encoded in MPEG 2 format. If you download the "shark codec pack" this will contain the codecs you require to view the stream.
Mar 14, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Pixel view pro3 SAA7130 TV Tuner/FM Radio/Video PCI Capture card after installings it says adding video tee smart failed what will be the reason for this problems
Pixel view pro3 SAA7130 TV Tuner/FM Radio/Video PCI Capture card after installings it says cannot render video capture pin to null filter plz help me
Jun 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
When ever i start tv tuner program(honesttech TVR) my pc get freeze i have SAA7130 TV tuner installed in my pc
is this tuner new or old and is ur pc new or old. if ur pc is old then place the tuner in another pci slot and then check out if that doesnt work then check the system requirement of the tuner that is in the manual and properly configure ur pc according to the requirement
Sep 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
PC TV PCI Internal Card w/ Phillips SAA7130 PCI TV Card
You don't need to do anything with the modem at all, other than remove it. Uninstalling the modem drivers will not affect theTV Tuner. Removing the card will disable the feature automatically, so dont worry about that. As far as the TV tuner is concerned, just pop it in, and install the software. If the software is giving you troubles, try going to manufacturer's website and search for drivers.
Aug 06, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Server power issues with PCI cards
Have you tried inserting it in a different PCI slot? I understand that this one in not faulty, but obviously the HP isn't getting its POWER OK signal ...
Mar 18, 2009 | HP ProLiant ML110 Server
Philips SAA7130 internal TV tuner card sound problem
hi,
try on a different slot on the pc or if you have another pc try using the tv tuner on another pc
if it still doesn't work your tv tuner card is bad.
further queries are welcome
Feb 18, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
P4p800-vm pci slot is not recognising the add on card ( TV tuner)
There is no PCI-E slot on this motherboard. It has an AGP 8x slot and 3 PCI slots, but no PCI-E. Therefore, even if you could manage to get the PCI-E card physically into the slot it will never work.
Here is a link to the manual - http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Dec 30, 2008 | ASUS PCI Express Graphic Card
PCI slot / TV tuner error
i am not an expert, but have lots of experience with my own media center. by moving the tuner card you changed the address of it which if the os does not recognize new hardware, it will not install the drivers for it. i believe you will have to use the device manager to reinstall the drivers for the tuner card. also will have to redo the setup for the tuner in media center. another problem with the softare change is you have to update the security components to be able to view certain channels.
you can find the best information for all these subjects at your computer manufacturers support website and of course microsoft for the security components. good luck, it should not be too difficult to solve your delemna with a little research and searching there.
Oct 07, 2008 | Sony VAIO VGC-RB42G PC Desktop
Gateway GM5084 PC Desktop Logo
109 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
