Question about Canon imageRUNNER 1310 Printer
We just received some used Canon Image runner 1310 copier/printer and I not have it hooked up to my computer. It is printing just a little off....it slants to one side. Any idea's why?
  • 1 more comment
  • msutherland Jan 28, 2009
    It prints just fine...it is just not straight on the page. For example doing a timesheet form which has a straight line across the top. It is lower by about 1/4 inch on the right. So the print is not level across the page. We got these machines without any books,etc. I also can not figure out how to have it take paper from the back instead of the tray.
    The data list also printed crooked. It does print like the paper went in a little off.
    I dont' want to print from it all the time but will once in a while. I did try the paper select button....it does not give me that choice...it says "Supply Rec. Paper S.B.: So I add a piece of paper and then it comes up S.B. Free with Text written under it or LTR with text under. I tried printing with the SB choice and a piece of paper in back...but it still printed from cartridge.
  • Carlos Perez
    Carlos Perez May 11, 2010
    what happen if you print lets say a user data report? need more info
    Scholar:
  • 62 Answers
Hi, wel now that you have two questions i still working on your first :P
this copier may only take paper from two diferent trays.
one is named the multi-purpose tray an dthe other just the cassette.
so i gathered you want to print using the MP tray, right? to copy from the bypass (or MP) tray, just choose it using the paper select button (take a look at the panel, there's a button that actually says 'paper select') . now if you want to print from it, go to your printer settings and change the default paper source to the mp tray.
about the other problem im still trying to figure out your problem.
Posted on Jan 28, 2009
  • Carlos Perez
    Carlos Perez Jan 28, 2009
    now about your printing issue. you told me that the user data list report came out printed Ok? or it also came bad? is it printing like if you intentionally put your original a little crooked? unbalanced?
  • Carlos Perez
    Carlos Perez Jan 29, 2009
    dude you shouldnt have locked this up i was still looking up trying to help
How do I make a copy using the bypass tray with card stock on the canon image runner 1310?
You have to select the paper tray(in this case bypass)when you make a copy.
Dec 10, 2014 | Canon imageRUNNER 1310 Printer
I have canon image runner 3035. I want to know to know how to scan
you can find manuals here:
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2230_2230g_2270_2830_2870_3530_3025_3030_3035_3045_3530g_3570_4570/imagerunner_3035#BrochuresAndManuals
Jul 25, 2010 | Office Equipment & Supplies
I need to know what is the kind of drum a Imagerunner 1630 uses.
An OPC Drum is used, you can use Drum of these models image runner 1310, 1330. 1370, 1510, 1530, 1570
Mar 29, 2010 | Canon Image Runner 1630 Copier Copier
Blank sheets when Copying on the Canon Image Runner 1310.
Hello sir; I would like you to check the charge corona wire inside the drum cartridge or you just replace a new drum cartridge, before you change also check the discharge corona wire at the bottom inside the machine.
Sep 17, 2009 | Canon imageRUNNER 1310 Copier
Cannot print to canon c2880 image runner from vista 64 laptop
Sounds like you don't have the proper Vista x64 bit driver installed. It's different from both XP and standard Vista Drivers?
Get it here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2269&modelid=14357
Jul 23, 2009 | Canon imageRUNNER 5020i Copier
Canon IR3035 Print orientation
you set the setting the way you want them, the go to additional functions/common settings/store and that should help
Apr 08, 2009 | Canon imageRUNNER 3035 Black and White...
Canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Jpg format images are not poper printing in image runner 400
OPEN THE IMAGE IN MSWORD. SEE IT IN PRINT PREVIEW AND THEN PRINT
ALSO TRY
1. USE GOOD QUALITY PAPER & DONT KEEP PAPERS OPEN AS THEY MAY ABSORB MOISTURE
2. CLEAN TOP GLASS WITH COLIN OR OTHER QUALITY PRODUCT
3. CHECK THAT TOP COVER IS GIVING ENOUGH PRESSURE ON YOUR ORIGINALS
Sep 21, 2008 | Canon imageRUNNER 400S Copier
Imagerunner 1310 does not photocopy
Do you have toner/drum cartridge in machine installed?
May 14, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 1310 Printer Logo
106 people viewed this question
old marine
old marine
