Cozy wall heater working intemittently
One night our cozy wall furnace (w355f) stopped working. Being a guy, I tapped on the gas valve (not the shut off valve) and the heater started working again. Problem repeated so I replaced the gas valve. worked fine for a while (days) then problem repeated. Replaced the pilot generator (even though no problem with pilot staying lit). Same thing -- Worked for a while tapping the valve got it working then it stopped again. But then the burner started cutting out. When it came on, it would stay on for 3-4 seconds then off. Not being too many more parts to replace, I replaced the thermostat. Initially it would cycle fine as the t'stat was adjusted. Now, we're back to the intermittant working and the burner cutting out......HELP!!!!! I'm thinking the only piece left to replace is the burner assembly otherwise one of the new parts are bad
  • ro2629 Feb 21, 2009
    I have a Cozy wall heater also, replaced thermastat with new white rogers only to find out that thermastat isn't the problem..Cost $200.00. Tech had to come out again, this time states that it is the gas valve that needs to be replaced, low flame,,,cost an additonal $174.00 . Could this truly be the problem or I'm I just getting ripped off? Yes, I am a woman and trying to find an answer and someone honest to deal wiith.
    Scholar:
  • 54 Answers
Sounds like a limit switch is tripping.
This appliance is equipped with a manual reset blocked
flue switch designed to protect against a blocked flue condition,
which would cause combustion products to spill back into the
living quarters. NOTE: A partially blocked, inadequate, or
disconnected vent system may not activate the switch.
Discoloration of the grille is an indication of a bad vent. If this
occurs, the vent can be checked by a qualified serviceman using
a draft gauge. After 15 minutes the gauge should read between
-.02 up to -.04 inches w.c. Vent must be checked at the
beginning of each heating season.
Posted on Jan 28, 2009
Help! I have a cozy wall heater model W355F-D. I have never ever lit a pilot light in my life and honestly, Im a little nervous. Can you maybe help me and walk me through it?
You should have control knob on the gas valve that has off, pilot and on , turn knob to pilot and hold in you should have igniter button press this in and it will spark at the pilot you may have to press this a few time to get pilot to light . when pilot is alight still hold knob in for 30 seconds then turn to the on position .
Nov 19, 2016 | Cozy Heating & Cooling
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
Cozy w355f single sided gravity furnace (Nat.gas) Does not want to light using the thermostat(COZY thermo). Have 565or so millivolts at the thermo.Tap on the gas valve and in then lights. loosen and...
It's possible that tapping the valve may be just enough to make the cylinder inside the valve move. Gas is impure and causes a sticky residue that causes valves to stick. If you are sure you MV is correct and that you have no loose connections, it may be the valve itself.
Apr 01, 2017 | Heating & Cooling
I have a cozy gas furnace that only comes on when you bump it.
Hi loose connection in the heater or sticking fan or gas valve
Jan 09, 2010 | Cozy (W352E) Heater
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
Gas valve only opens when struck lightly
Sounds like a a bad gas valve, not serviceable - replace.
Apr 30, 2009 | Cozy (W352E) Heater
Cozy one sided wall furnace (no blower motor)
This is a weird one, but make sure all the wire connections are in the correct place. I accidentally miss wired a heater like this and it did the same thing.
Nov 27, 2007 | Cozy (W352E) Heater
Heating & Cooling Logo
259 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
