Question about Symbol MC70 Barcode Scanner
Can not synch the Barcode Scanner. Error is shown below
Barecode Scanners ARE NOT SYNCHING WITH THE EXCHANGE SERVER
THE ERROR ON THE DEVICE IS
ADO EXCEPTION: UNSPECIFIED ERROR
448 BLOCKS SENT TO SERVER, 1 BLOCKS RECIEVED
COMPERESSSION FACTORS 73%UP /70%
SYNCH INCOMPLETE
"Tab" "Enter" "BackTab" Suffix Barecode scanner
hi,try this software, but the complex action you want may not be possible.
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12668&sliceId=&dialogID=489094888&stateId=1%200%20489090306
It could be better to create a barcode that has these codes.
many readers only let you have 2 post-amble codes, eg code that are automaticlly added after you have scan your bar code. problem with this it will happens every time you scan something, which is not always desirable.
regards
dave
Mar 04, 2013 | Symbol LS2208 Handheld
Usb port open error
Does it work on other POS machine? That is to verify any hardware issue with the scanner. If it works, does other scanner works on this POS machine? Sometimes unplug and replug some USB cable in or some of the cable in between the POS and scanner will make it work. If those do not work, try to check the server for POS connection and see whether they can see that POS system. Use your store control application to reset that POS machine before you refresh the software or operating system on that.
Sep 11, 2012 | Datalogic Magellan 1100i Barcode Scanner...
I am not able to delete emails (header delete).
Could be your phone is configured in imap or exchange mode. Try synching to the server after clearing up the mails in the server using a computer.
Mar 07, 2011 | Nokia E63 Cell Phone
How do I synch my copier/scanner with my computer?
this machine does not have scanner option. therefore cannot be synch to scan toyour computer
Nov 17, 2010 | Copystar CS-1810 Copier
Symbol MC9090 Barcode Scanner cannot enable scanner error code "A0000008"
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software. Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Oct 21, 2010 | Symbol MC9090 Barcode Scanner
How do I synch outlook 2003 with iphone
You didn't say whether you're trying to sync everything (mail, calendars, contacts) or just some things or one thing (like contacts only). I don't know if you're using an Exchange server or even if you have the info you'll need to sync with an Exchange server.
I have a Windows mobile device (AT&T Tilt) running Outlook 2007 and everything is sync'd. We also started purchasing the iphone for our employees and sync their email, calendar and contacts to their phone.
I could probably give you step-by-step information (based on how I do this for my users at work) if I knew whether you'll use iTunes to do this or Exchange Active Sync and what you want to sync between your phone and outlook. One method (iTunes) will only update your data between Otulook and the phone when you connect it to the computer with Outlook configured on it but, the way we do it at work, they receive email, data, changes, etc in real time.
Try using this link http://www.apple.com/support/iphone/mail/
What you will find here is support topics and instructions for Exchange Active Sync, setting up email accounts, troubleshooting for contact and calendar syncing.
You can also search support on Apple's Web site. Entering the keywords: iphone outlook 2003 will bring up a lot of support info.
You can use iTunes or MobileMe for synchronization. If using iTunes then try this:
You can configure which items are synchronized during a one time set up process. After initial set up, each time you connect the iphone to your computer, the changes made on your computer or device are synchronized.
  1. Connect your iPhone to your computer. iTunes should open automatically.
  2. In iTunes, in the source list, under Devices, click the entry for your iPhone.
  3. Click the Info tab.
  4. Select which items you would like to sync. For example to sync only calendars, under Calendars, you would click Sync calendars from, and then click Outlook.
  5. Do one of the following:
  • To synch all calendars, click All Calendars.
  • To limit the calendars that are synched, click Selected calendars and then click the calendars you want to sync.
6. Click Apply.
Hope this helps!
Thanks for using Fixya and you can let me know how helpful I've been by rating this solution.
Apr 03, 2009 | Apple iPhone Smartphone
I have this situations: my system don't read any code begining with 0, please need this configuration for symbol LS2208. Thank you.
Your scanner must have been delivered with a "Quick Start Guide".
All you need to do is to scan the following barcodes from thar Guide:
1.Set Defaults
2. Scan Options
3.<Data><Suffix>
4.Enter
5.The barecode for whatever type of connection you use (RS232, Keyboard, etc.)
Jan 30, 2009 | Symbol LS2208 Handheld
Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
Symbol MC70 Barcode Scanner Logo
399 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
