Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
Problem for Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
Sharp SF 2114 H-4 Error: Fusing Unit Not Heating
By christine244 on Jan 28, 2009
I rec'd an H4 00 error on Sharp SF 2114. After research I believe it is a code for "fusing unit doesn't heat up".
Is this copier even worth fixing?
Can we fix this ourselves w/service guide or better to call in help?
Do you know the approximate cost and best place to get this part(s)?
This site is amazing! Thanks a heap!
Comments:
Jan 28, 2009
- I just talked to our copy repair man.....he had me push C (clear) then 00 (zero, zero) then C (clear)....that cleared the control panel. Then I pressed 1 (one) then 4 (four) and start. He instructed me to turn copier on and off to see if maybe it was giving 'false' code. After about 2 minutes the code came back. I am waiting further information on if we will repair or replace based on cost.
Wanted to post this to see if it might help someone in the future.
Best Solution
posted on Jan 28, 2009
Helpful)
wturner643
Rank: Apprentice
Rating: 79%, 3 votes
IMO, it might not be worth fixing. Many of the supplies have been discontinued, toner for example. While you can still get aftermarket supplies, the repair costs if you can find the parts may be more than the machine is worth.
Was this helpful?
Yes
No
Solution #2
posted on Nov 10, 2009
Very Helpful)
toniruku
Rank: Wiz  Sharp Expert
Rating: 85%, 38 votes
Replace fuser lamp and check the condition of thermistor and rectify.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sharp -COPIERS - AR-5316
Questions and Unsolved Problems for Sharp -COPIERS - AR-5316
Do you recommend Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier?
Answer
Answer
im facing one problem if e 004 service code for canon 7161 what is the solution?
Answer
5/19-20 T trmai E trmakr J krijaniburrie 71120
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp -COPIERS - AR-5316...:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
