2009 Ford Fusion ... Front Proc 1 Note ... Front Proc 2 Note ... Do not attempt to tighten the nut with the vehicle on the ground or the wheel bearing will be ...
Dec. 2, 2019 - Im replacing the front wheel bearing assemble this weekend and cant find the torque spec for the ale nut. The older model Fusion (up to 2012) ...
the four axle nuts, 98 ft lbs, tighten in criss-cross pattern.
The hub nut/wheel bearing, 148 ft lbs, use new nut, don't let vehicle weight sit on the ground while torqueing, it could damage the wheel bearing.
If I left something out, give me a holler.
Here are the front axle nut torque specs for the 2004 Chevy Silverado 2500HD:
• Axle Shaft nut - 177 ft-lb
• hub and bearing assembly to steering knuckle bolts - 133 ft-lb
The front wheel bearing is a hub and bearing assembly. To remove you will....
1. Remove the tire
2. Remove the axle nut. You can put a punch in the fins of the rotor to keep the assembly from turning while you rmove the nut. You can can do the same thing when you torque the axle nut.
3. Remove the caliper and rotor.
4. Unplug the abs sensor if equipped.
5. Remove the three bolts that hold the hub to the knuckle.
6. Rmove the hub.
If you need torque specs let me know and i'll get them for you. It is absolutely critical that you torque the axle nut to the proper spec!
