Question about Epson Office Equipment & Supplies
How to access waste pads in Epson rx425
Followed links to ssc utility and reset counter, printer now functioning fully. Where within the printer are waste pads located and how to extract, wash and replace?
  • smiffyg56 Feb 03, 2009
    Have managed to download full service manual from printer1.blogspot.com. Which suggests removal of document cover/ paper support assembly/stacker/scanner unit/panel unit/ housing upper/printer mechanism before being able to access the waste ink pads, about 12 pads in total.
    Think the answer may have understated the job a touch, but appreciate the speed of reply.
    Regards,
    Garry
    President:
  • 2,559 Answers
They are located directly under the print cartridge when in the resting position.They can be removed with tweezers.
Please rate this fixya
Posted on Jan 28, 2009
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Jan 27, 2016 | Epson PRINTER,ARTISAN 730
Both the red and green light are on and blinking.What is wrong with my Epson C60?
kiryakitsa1 You should download the SSC Service Utility as pineworks says. Read the instructions and warnings. Go to Reset counter protection and press reset. You may recieve a warning about replacing your waste ink pads. I have always reset the protection counter without replacing the waste ink pads and I have never had a problem. If you see ink drainage then you should replace the waste ink pads and then reset the protection counter. I have never had a problem with ink heads and I have done this many times.
Feb 07, 2010 | Epson Stylus C60 InkJet Printer
How to reset 73/91 Cartridges for Epson CX5500
SSC utility is used for resetting waste ink counter, not for ink level counter (chip at ink tank). If you wish to reset ink level counter (chip), you must use hardware resetter, or use CISS chip with autoreset function.
Oct 18, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
Stopped printing service required? how to get around
Ok, the key problem here is that your printer has indicated the waste ink pads in the printer need changing because they're full of waste ink.
Resolving this is a two pronged attack.
1. Download the SSC utility from here:
http://www.ssclg.com/epsone.shtml
Install then run.
Under configuration choose you RX425 printer then in the "printer model" field choose the "Epson Stylus CX4600(4500)/CX36x0(3500)/RX42x(430)/MP-A700" option.
Click on the top right X as if you were closing the utility and you'll see a little printer icon appear in the system tray (series of icons in the bottom right hand corner of your screen usually).
Right click on this and locate the "Protection Counter" and under this the "Reset Protection Counter" and "Clear counter overflow"
Then turn off your printer and turn it back on again. You should be able to print again now.
2. BUT... You still have a printer with close to full waste pads so you need to deal with that. WARNING: Ignore it and expect to get a puddle of waste ink flowing out of your printer at some point!
Various instructions for dealing with this are available here:
http://www.continuousink.info/forum/viewtopic.php?t=4128
... and you can opt for a pre-built kit or just do a DIY with parts you've sourced yourself.
Hope that helps :)
Jan 18, 2009 | Epson Stylus RX425 Multifunction...
Error message and red exclamation indication
Finally figured out the problem.
1. Took waste pad out and cleaned with paper towel. Couldn't find a replacement waste pad, so needed to clean it instead.
2. Downloaded SSC Service Utility software (free) in order to "Reset the Protection Counter". This is an option within the utility.
Printer must be on when running the SSC utility.
Oct 28, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson stylus 1400 service utility SSC
The free SSC utility which will reset the waste ink pad protection counter in most Epson inkjet printers can be downloaded from
http://www.ssclg.com/epsone.shtml. Remember though, if you don't change the ink pads, there will be an increasing danger of ink leakage from your printer, particularly if you tip it up for any reason - VERY messy, and it can clog up your printer mechanisms.
Apr 11, 2008 | Epson Stylus 1400 InkJet Photo Printer
EPSON 360
download a ink pad reset utility at epson.com/ipr or there are some other 3rd party s/w for ink pad reset
Feb 19, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson stylus c45
you need to download the resetter program the counter will have reached its limit and needs to be reset, it is fairly simple.
Dec 15, 2007 | Epson Stylus C46 InkJet Printer
256 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
